| The pin on the tiller crossbar http://www.hobie.com/au/en/forums/viewtopic.php?f=24&t=47356 |
| Author: | BANDITO [ Fri Apr 26, 2013 7:47 am ] |
| Post subject: | The pin on the tiller crossbar |
The steel pin on the tiller crossbar becomes loose bone as I do to stop this? Thank you. |
| Author: | mmiller [ Fri Apr 26, 2013 7:59 am ] |
| Post subject: | Re: The pin on the tiller crossbar |
Not sure of what you refer to, but if the pin at the end of the tiller crossbar? You can use LocTite or epoxy to hold it in the plastic end fitting. |
| Author: | BANDITO [ Fri Apr 26, 2013 8:40 am ] |
Thank you understood well is in fact the pin end cap (code 37561203) of tiller crossbar. |
