| Bridle Eyestrap Anchor http://www.hobie.com/au/en/forums/viewtopic.php?f=24&t=62544 |
| Author: | Gibbsak [ Sat Apr 21, 2018 4:04 pm ] |
| Post subject: | Bridle Eyestrap Anchor |
While replacing a bridle eyestrap, the bolt has been epoxy set into the anchor, and I ended up breaking the bolt in the anchor. While trying to drill out the bolt, the bit snapped. It is taking forever to drill out and try to re-tap. Is there an easier way? |
| Author: | Gibbsak [ Tue Jul 03, 2018 9:09 pm ] |
| Post subject: | Re: Bridle Eyestrap Anchor |
[url]https://photos.app.goo.gl/yY4uJPYXGS9aXas99 [/url] |
| Author: | mmiller [ Fri Jul 06, 2018 10:06 am ] |
That would require something different to fix. Maybe bolts through the hull from side to side below the insert to mounts a bale or strap to hang the bridle on. ![]() This is the idea, but since one bolt is sheared. Mount a strap up a bit to hook the bridle direct. |
