| Hobie Wave Vs Bravo? http://www.hobie.com/au/en/forums/viewtopic.php?f=24&t=66726 |
| Author: | KingstonKai [ Tue Jun 16, 2020 12:29 am ] |
| Post subject: | Hobie Wave Vs Bravo? |
Interested in a Hobie Wave. I have a utility trailer (~ 4' 6" wide, 10' long) and I'm not really interested in buying / registering another trailer for a catamaran. Are the Wave's hulls easily separated /rejoined to the trampoline for more compact transport to fit on my current trailer (i.e. without deconstructing the tramp lacing)? Thanks |
| Author: | mmiller [ Tue Jun 16, 2020 10:19 am ] |
| Post subject: | Re: Hobie Wave Vs Bravo? |
Throw a couple 4x4s on there to make it wide enough? Way easier than disassembly. You need to undo the tramp to disassembly, so that can be a pain if it is a Club version... 3 piece tramp with lacing. The classic is easy and quick to disassemble. |
| Author: | Brian from MA [ Tue Jun 16, 2020 2:43 pm ] |
As Matt stated it is a pain to disassemble a Wave with a tramp. I did it each off-season to store my Wave and it was a work out to assembly it each spring. But on the plus side it was great to be able to disassemble it each winter so I could store it in my garage attic. Another idea for you to consider is using strut channel instead of 4x4s to widen the trailer. When I had my Wave I modified/widened a small boat trailer with strut channel. It's 1 5/8" square steel channel found in the electrical section of Home Depot. It's sold in 10' lengths and I have a chop saw for metal that I used to cut it, but you could probably cut through it with a metal hack saw as well. I choose the strut channel because it has slots along the whole length so I could easily mount rollers and it was easy to hook ratchet straps onto the strut. I also mounted a sail tube onto the strut. Obviously 4x4s would work just as well, I just choose the strut because I use it for my work. Just offering another idea. Good luck. |
| Author: | Lt.kenson [ Sun Jun 21, 2020 7:09 am ] |
I modified a trailer that we used to carry kayaks, to carry my Bravo, it's not difficult. I too asked the same question, Wave vs Bravo to re-learn sailing after 40 years and went Bravo for the furling sail. I will buy a Wave pretty soon as that HARD plastic is hard on my old joints and butt, lol. Anyway, back to the point, I will modify the trailer as needed when I get a Wave. |
| Author: | fbn [ Sun Jul 12, 2020 11:52 am ] |
Hi KingstonKai, I recently modified a utility trailer in the manner that mmiller mentioned. I bolted a few 2x4s to the trailer to widen it and cut up an old rug I had to provide some padding. I put an extra 2x4 on the very front support as the bow of the hull rises up a bit. This arrangement has been working out, but I do wish I had used something a bit thicker than a 2x4: the center of the 2x4 bows upwards a bit with the boat on the boards. I'm planning to add some more supports and finding a way to reinforce it a bit. |
