| Rigging Harken 40 mm Double Carbo Block w/ 1 Ratchet http://www.hobie.com/au/en/forums/viewtopic.php?f=24&t=69815 |
| Author: | FirstWave [ Mon May 23, 2022 7:27 pm ] |
| Post subject: | Rigging Harken 40 mm Double Carbo Block w/ 1 Ratchet |
Hi I purchased Harken Fiddle Block - 40mm / 471 Carbo-Cam and Harken 40 mm Double Carbo Block w/ 1 Ratchet but am unable to locate information regarding rigging. https://www.harken.com/en/shop/carbo-ai ... lery&pid=1 https://www.mauriprosailing.com/us/prod ... SB411.html |
| Author: | Wavesurf57 [ Fri May 27, 2022 2:04 pm ] |
| Post subject: | Re: Rigging Harken 40 mm Double Carbo Block w/ 1 Ratchet |
Hi, I have the same set of blocks and they work great, i looped the rope end at the fiddle block and sewed it together with sail thread and heat shrink tubed over the joint instead of a bulky knot, although its kind of a hack its strong and works well. Good luck |
| Author: | FirstWave [ Sat May 28, 2022 12:19 pm ] |
Can you send me a picture of how to route the lines. I can't figure it out. Thank You |
| Author: | xfactor989 [ Mon Jun 06, 2022 6:23 pm ] |
FirstWave - I think you going for this setup: https://www.murrays.com/product/harken- ... et-system/ There are a couple pictures of it setup. It also looks like you need the 281 micro eye strap. I ended up tying a figure eight knot for use in the eye strap as my other knots were rubbing on the line. Wavesurf57 - What size line are you running? I am running 8 mm and thinking of going smaller as it seems a little tight. After purchasing I see different sites have the maximum line size listed as 6mm, 8mm or 100 mm for the same part. |
| Author: | Ninjabones [ Tue Aug 16, 2022 11:59 am ] |
This is a good video on rigging a 6:1 mainsail system https://youtu.be/YojZ-gjrc90 |
