| Rudder assembly problem http://www.hobie.com/au/en/forums/viewtopic.php?f=24&t=8588 |
| Author: | Kevin Pierce [ Sun Jan 13, 2008 2:28 pm ] |
| Post subject: | Rudder assembly problem |
I have a problem with my rudder assembly (old, or original style): On both rudders, I have lost the small, spring-loaded piston that acts to secure the locking cam device above it. As a result, the rudders will not lock in place. Can this piston-like piece be ordered and replaced? If my description is lacking, let me know and I'll take and post some photos. Thanks for any help. Kevin |
| Author: | sunjammers [ Sun Jan 13, 2008 2:43 pm ] |
| Post subject: | |
sounds like you need a rudder locking kit. The spring your are referring to applies tension to a plunger while holds the cam in a locked or unlock position. You can get just the spring if your plunger is still there and in good shape. The parts will be the same as on a H17 and H18
| Author: | Kevin Pierce [ Mon Jan 14, 2008 8:04 am ] |
| Post subject: | |
Yep, that's it. Thanks a bunch. Kevin |
