| Hobie sport or outback?? http://www.hobie.com/au/en/forums/viewtopic.php?f=26&t=3536 |
Page 1 of 2 |
| Author: | basstard [ Sun May 07, 2006 9:41 am ] |
| Post subject: | Hobie sport or outback?? |
Hi, I'm new on here, but not so new to the kayak fishing game - Stuie. |
| Author: | OffRoad [ Sun May 07, 2006 4:47 pm ] |
| Post subject: | |
Welcome basstard Are you fishing in salt or freash water? I would get the sport because I think it is more versatile. |
| Author: | Windrider [ Sun May 07, 2006 7:15 pm ] |
| Post subject: | |
Basstard, OffRoad asked an important question, where will you be using it the most? I am sold on the Mirage Drive and tested the Sport, Outback, and the Adventure. I bought the Adventure because I only do big water. I didn't care much for the Sport at all because is seemed like a toy, but that is just me. The Outback was too wide for me and difficult to get in and out of because I'm short. If you have narrowed it down to just those two and you want to stand, I would recommend the Outback. If you are going to be on the ocean or big lakes, give the Adventure a look. If possible, try them all before you buy. |
| Author: | basstard [ Tue May 09, 2006 2:02 am ] |
| Post subject: | |
yea, I am big on freshwater, love chasing the elusive bass, so freshwater rivers creeks, dams and lakes are more my scene, however the only reason why I haven't ventured out on saltwater is that up until now I really haven't had the chance. I see your point with the outback with storage space e.t.c and have considered the adventure or a faster bigger yak alike which I have plans to buy down the track, however accomodating such a big yak is a problem. My instincts tell me the sport, but mmm.. i still just don't know |
| Author: | Noalias [ Tue May 09, 2006 10:32 am ] |
| Post subject: | |
Regardless of which model you choose you may want to consider the Sidekick outriggers (amas) that are soon to be available. My Outback is a very stable platform for me at about 88 kilos however I don't fish while standing. I will be buying the Sidekick when it becomes available because I also sail the kayak, but standing will then be an option. Might be nice to be able to stretch the legs on occaision and improve the sight fishing when looking for floating kelp paddys. |
| Author: | Richie [ Wed May 10, 2006 9:33 am ] |
| Post subject: | go sport |
I have a sport and an outback. The outback is a beast to both put on cartop and to paddle. My wife's sport paddles a lot swifter. I do like the outback though for Lake fishing and hopefully in the Gulf of Mexico soon. The peddle drive is 2x as fast and effortless vs paddling. |
| Author: | pk [ Thu May 11, 2006 11:59 pm ] |
| Post subject: | |
I know the outback is faster, but how much faster than a Sport? I'm in the same boat as you are basstard, I'm 5ft 7 160lbs and can't decide between a sport or outback. I'll be test paddleing them all next month, even the Adventure, but I'm not sure if I like the ideal of a 16ft kayak in the back of my small pu bed, especially sense I won't be doing any saltwater fishing. |
| Author: | pk [ Fri May 12, 2006 12:00 am ] |
| Post subject: | |
Dryness, I've read in a few posts about the dry ride a Outback will give you. How about the Sport? I know a few of the members of this post have both so your opinions would be great |
| Author: | OffRoad [ Fri May 12, 2006 7:00 am ] |
| Post subject: | |
The Adventure will be the fastest and also the hardest to turn in a small area ie river. Outback is the widest so it’s the driest. Quote by Richie “sport paddles a lot swifter†|
| Author: | Apalach [ Fri May 12, 2006 7:10 am ] |
| Post subject: | |
basstard (and others), I have both. Even though I bought the Sport for my wife, that is all I use now when she is not along--for freshwater, estuaries and bays, and even offshore ocean fishing in the Atlantic (once). Your height and weight are perfect for the Sport, but the Outback will seem very tippy to you unless you add about 75 lbs of gear, sandbags, or concrete blocks(!) to get the sponsons down in contact with the water. As to speed, the OB will be faster, simply because it is longer. As to a dry ride, the OB will be much better. The Sport has less freeboard and can be a bit of a wet ride in chop since you are much closer to the bow. But I wear waterproof pants (and jacket, if need be), so the wet ride has not bothered me too much. The OB, because of the hull design and length deflects water much better than the Sport, and even better than the Adventure from what I hear. I also especially like the lighter weight of the Sport since it does not aggravate my back problems when lifting it onto my trailer or loadXtender. If you cartop (which I have also done) you will probably like the Sport better as well, especially if you have a tall vehicle like a SUV. If you have a PU, and can simply lash your yak down in the bed, that is probably the best transport option (IMHO), since weight considerations won't matter much there. Good luck. Dick |
| Author: | basstard [ Sat May 13, 2006 12:39 am ] |
| Post subject: | |
thanks for the input ppls, keep em commin' [quote][/quote] |
| Author: | Apalach [ Sat May 13, 2006 7:10 am ] |
| Post subject: | |
bass, Yep--casting with rods sticking up behind you can be a problem. I try to remember to angle the rod tip out to the side when casting. Although I prefer to cast straight out over my head or shoulder for accuracy, this is usually not possible without fouling a rod tip somewhere behind, or to the side of, you. |
| Author: | basstard [ Sat May 13, 2006 4:35 pm ] |
| Post subject: | |
hmmm... is this only happen with you in the sport, or is it a problem that ocurs in most yaks? |
| Author: | Apalach [ Sat May 13, 2006 7:47 pm ] |
| Post subject: | |
Actually, I seem to recall that it was more of a problem in the OB, due to its greater width. Of course, if you have an empty gunwale bungee , you could lash the rods down there to largely eliminate the problem. |
| Author: | pk [ Sat May 27, 2006 3:29 pm ] |
| Post subject: | |
I was going to demo all three next month, but decided to purchase the Sport from KFS this weekend. With JONS advice from KFS and after reading all your guy's post I decided on a SPORT. I'll be on vacation in TX in July and want to hit the lakes the first day, if I demo them then ordered it from KFS I would have to wait a week and waste half my vacation time. I think getting the SPORT for my freshwater needs is going to work out great, if I want to upgrade to a bigger/faster/ocean yak later, I'll get the Adventure or maybe even the rumored Revolution. Either way, I'll think I would probably want to keep the smaller/handy Sport. Thanks for your replies and all the hundreds of posts that I have read of yours on this and the KFS site. PK |
