| Yakattack Gear Trac for Revo 13: GT90 or GT175 http://www.hobie.com/au/en/forums/viewtopic.php?f=26&t=52850 |
| Author: | Aggie61 [ Wed Sep 10, 2014 6:16 pm ] |
| Post subject: | Yakattack Gear Trac for Revo 13: GT90 or GT175 |
Wanting to add Yakattack Gear Trac to 2015 Revo. Been researching and some have recommended the GT90 all around and others recommend GT90 for side rail behind the seat and GT175 forward of the mesh pockets up front. Any advantage of using the GT175 up front over the GT90? |
| Author: | Wintersun [ Thu Sep 11, 2014 9:49 pm ] |
| Post subject: | Re: Yakattack Gear Trac for Revo 13: GT90 or GT175 |
The GT90 is half the width of the GT175 track and 1/8" less in height. I used it with my Revo 13 boats as the sides are very narrow on the boat and the wider rail would simply sit outside the edge of the plastic and not provide any additional lateral support and it could possibly block the slots for my feet when paddling. On one side I installed a 16" length of track and on the side with the cam cleat for the sail rigging I only had room for a 12" length of GT90 track. |
| Author: | Billamicasr [ Tue Nov 11, 2014 3:46 pm ] |
Hi Pmmpete, First photos I've seen of your Revo. In another forum I mentioned I was going to look at both the Revo13 & the Outback as soon as they arrive at Scappoose Bay kayak center. One of my concerns on the Revo was the Gear Tracks. There isn't much room for equipment, you've done a great job of it to extend the usefulness of the tops side of the deck. I apprecaite seeing those photos; thanks for posting. RV / Billamicasr Aka: Yak-Angler = Website is almost ready |
| Author: | pmmpete [ Tue Nov 11, 2014 5:33 pm ] |
For a couple more ideas about how to outfit a Revolution, here’s how I mounted a modified Cannon Lake-Troll downrigger on my 13’ Revolution. ![]() Here’s the entire downrigger setup in operation. ![]() This downrigger setup is described in more detail in a posting at http://www.northwestkayakanglers.com/in ... ic=12575.0 . I explain how you can make your own devices which mount on gear tracks in a posting at http://www.northwestkayakanglers.com/in ... ic=13167.0 . |
| Author: | Billamicasr [ Wed Nov 12, 2014 11:36 am ] |
You must have been an engineer in this life or possibly another. Clean install, appreciate the photos. Haven't spent time with a down-rigger. I've got a 10 to 15 year old new Scotty hand cranked model that is still new and probably covered with dust. Wonder which box that's in? If I get to do hands free fishing I'll dig it out and give it a try. |
| Author: | Wintersun [ Thu Nov 13, 2014 2:34 pm ] |
Love the downrigger setup. Especially like that it is quickly attached and removed and not permanently attached to the kayak. I can see you started with determining the best location for the actual operation of the downrigger while seated in the boat. |
| Author: | pmmpete [ Thu Nov 13, 2014 6:38 pm ] |
Downriggers are a great fishing tool, and they are easy to use on Mirage Drive kayaks if they are mounted in a convenient location. It would be nice if Hobie offered a downrigger base similar to the one shown in my pictures which can be bolted onto Revolution kayaks. It would be easy to cast a pair of nuts into the gunwale of Revolutions for use in bolting down the downrigger base. And Hobie could easily have Cannon produce Lake-Troll downriggers with a shortened boom for use with the base. Hobie could also produce downrigger bases for use on Outback and Pro Angler kayaks. |
| Author: | staktup [ Fri Nov 14, 2014 7:04 am ] |
Although it was not too easy, I was able to use the mounting bracket bar on the inside of the hull and tighten it down with nylon nuts. I asked ACK to send me longer bolts which was needed. These were placed in the same location on the gunwales as yours, but I used 8" sections. |
