| New GT drive in older Outback? http://www.hobie.com/au/en/forums/viewtopic.php?f=26&t=55823 |
| Author: | csteven [ Fri Aug 28, 2015 2:31 pm ] |
| Post subject: | New GT drive in older Outback? |
I have an 08 Outback. Will the new GT drive fit? It looks different than the older drives, so im guessing no, but want to confirm. |
| Author: | Jbernier [ Fri Aug 28, 2015 3:10 pm ] |
| Post subject: | Re: New GT drive in older Outback? |
They do fit in older kayaks, all you need to do it remove the alignment pin from the spine, but beyond that small modification it will fit. |
| Author: | csteven [ Sat Aug 29, 2015 9:42 pm ] |
Jbernier wrote: They do fit in older kayaks, all you need to do it remove the alignment pin from the spine, but beyond that small modification it will fit. Thanks Jacques. I'm clueless - where is the alignment pin and how would I remove it? |
| Author: | Dr.SteelheadCatcher [ Sun Aug 30, 2015 6:33 am ] |
Check out this Hobie link. viewtopic.php?f=60&t=46677 You need to cut off the plastic alignment pins. It's quite obvious once you have the new drive in your hands |
| Author: | csteven [ Sun Aug 30, 2015 8:43 am ] |
Dr.SteelheadCatcher wrote: Check out this Hobie link. viewtopic.php?f=60&t=46677 You need to cut off the plastic alignment pins. It's quite obvious once you have the new drive in your hands Ok, thanks for your help! |
