| Help identifying a hole in PA17T http://www.hobie.com/au/en/forums/viewtopic.php?f=26&t=56536 |
| Author: | allbrite [ Tue Dec 01, 2015 8:39 pm ] |
| Post subject: | Help identifying a hole in PA17T |
New PA17T owner here. There is a hole that is located at the center of the kayak with two rubber stops. Is this a mast step? Can somebody answer this mystery for me? Thanks in advance. |
| Author: | mmiller [ Wed Dec 02, 2015 9:37 am ] |
| Post subject: | Re: Help identifying a hole in PA17T |
I'm guessing you are looking at the Lowrance ready through hull fittings? At 3:18 |
| Author: | allbrite [ Wed Dec 02, 2015 6:12 pm ] |
Matt, Thanks for your reply. What is the purpose of the rubber stops? Thanks, David |
| Author: | mmiller [ Wed Dec 02, 2015 6:19 pm ] |
Wire through hull access points. There are adapters included with the boat for different wire diameter and counts. Check the manual: http://static.hobiecat.com/digital_assets/89510-pro-angler-17-manual-141204.pdf Page 17-19 |
