| Transporting Berkley Gulp or Other Soft Baits 0n a Kayak http://www.hobie.com/au/en/forums/viewtopic.php?f=26&t=6579 |
Page 1 of 2 |
| Author: | Apalach [ Sun Apr 22, 2007 1:41 pm ] |
| Post subject: | Transporting Berkley Gulp or Other Soft Baits 0n a Kayak |
A “problem†|
| Author: | FishinFrank [ Sun Apr 22, 2007 3:11 pm ] |
| Post subject: | |
After I had a pack leak all in my pocket once (nice smell |
| Author: | Shep [ Tue Apr 24, 2007 4:52 am ] |
| Post subject: | |
Those plastic waterproof boxes are excellent. Some come with foam to put the more delicate items in. I used one set up like that for my camera when riding my ATV while stationed in Alaska. |
| Author: | paddlefisher [ Sat Oct 11, 2008 11:45 am ] |
| Post subject: | |
I know, old topic, but anyway, rarely use the gulp stuff, but have it always with me when fishing. tends to dry out once the package has been opened, but Hobie has a solution at hand, their "nalgene "bottle! bundle the packages and stuff them in, stays "fresh" for ages PF |
| Author: | Librarian [ Wed Oct 15, 2008 5:39 am ] |
| Post subject: | |
Small peanut butter jar. pick one that fits in cup holders, can also be layed sideways in gunnels. I've had gulp in one for two years and the fluid does not evaporate. |
| Author: | Choupique [ Thu Oct 16, 2008 3:23 pm ] |
| Post subject: | |
I leave all the packs upright in my seat pounch. |
| Author: | jd89 [ Mon Nov 17, 2008 10:59 am ] |
| Post subject: | |
I usually go with a simple zip lock bag. It makes it easy to dump them back in the Alive container after I get off the water, although I think I will give the peanut butter jar thing a try. |
| Author: | Clermont7 [ Tue Nov 18, 2008 5:24 pm ] |
| Post subject: | Other Plastic Problems` |
I went up the creek last week, saw a good spot, and popped open the built-in tackle tray in my Outback and discovered the Trick Worms that I had loaded in 2 weeks before were mostly mush. So much for bass fishing. After scraping the crap out of the tray I loaded a resupply in ziplock bags. Too soon old, too late smart. |
| Author: | bbuchorn [ Wed Nov 19, 2008 9:57 pm ] |
| Post subject: | |
Why not Buy the new container Berkley sells as "Gulp Alive" I found some New Penney Jerk Shad- looks like Bass or salt water assasins.Says "Recharge Baits" on the Label. I'm gonna put all my baits in there in there mixed. the colors don't run and the juice in the container "recharges" the used baits. Found some in a new shaped container Today. not your regular jar but a flattened oval. |
| Author: | Brazos [ Sun Nov 23, 2008 8:44 am ] |
| Post subject: | |
Apalach I always like yours and Roadrunners input it is always so precise and clearly illustrated. Thanks. Brazos |
| Author: | quirkster [ Fri Nov 28, 2008 2:25 pm ] |
| Post subject: | |
I got this idea from Jon S. I found the containers of gulp alive leak but these babies purchased at Kmart are locking, Watertight and preserve your gulp baits indefinately.
| Author: | quirkster [ Fri Nov 28, 2008 2:28 pm ] |
| Post subject: | |
Did I mention they come in three sizes. The one pictured is the middle size. The smaller one fits in the mesh compartments and they will all fit through the twist and seal hatch. |
| Author: | Horsebag [ Sat May 01, 2010 9:50 am ] |
| Post subject: | Re: Transporting Berkley Gulp or Other Soft Baits 0n a Kayak |
GULP bait container...low -profile type ,oval- shaped,screw-capped......CUT a small " X " openining thro' the plastic membrane leaving the edges of the membrane sealed around the opening of the container...pull out a bait with pliers...re-cap the container...store below hatch....,and ........NO LEAKS SO FAR . |
| Author: | Brazos [ Sat May 01, 2010 8:24 pm ] |
Horsebag wrote: GULP bait container...low -profile type ,oval- shaped,screw-capped......CUT a small " X " openining thro' the plastic membrane leaving the edges of the membrane sealed around the opening of the container...pull out a bait with pliers...re-cap the container...store below hatch....,and ........NO LEAKS SO FAR . ![]() ![]() ![]() Brazos |
| Author: | FishIt [ Sat May 01, 2010 8:41 pm ] |
I've been using Gulps since they came out and have never had a problem with the packages leaking unless damaged when opening... the zip seal (just like a zip-lock baggie) seems to work fine, and for carry-over from one season to the next. The Gulp Alive containers are leak proof and last forever. Some problems are that, even though the packaging says to re-charge by putting used Gulps back in the sauce, they don't hold to the jig head as well after they've been used once, the curly-tails are pretty tender and are easily bitten off and all of them dehydrate and shrink to a hard little piece of rawhide if left out of the juice... don't ever leave one on the jig head -- they're really hard to get off. But, they are effective baits........... stinky, but effective! One other caution: some other plastics (Bass Assassin, Exude and some Fin-Ess will get all gooey if you put them in the Gulp sauce... it ain't like a lot of the other attractants. Tight lines! |
