| Leaks in the REVO http://www.hobie.com/au/en/forums/viewtopic.php?f=26&t=8202 |
| Author: | mg2969 [ Sun Oct 28, 2007 1:52 pm ] |
| Post subject: | Leaks in the REVO |
Went hoopin for Lobsters for the first time to weeks ago and developed a serious leak. I was pump out @ 1" of water every 30 min from inside the hull. The next day after skunkin out I brought the REVO back to XTREAMLINE Sports in San Pedro. Greg water tested it and found a double leak !!! The plastic had cracked under the cams that lock in the mirage drive. Basically it started from the threads that hold the 3-4 in stainless steel bolts that hold the cams down. Unfortunately most of Hobie's staff was off on work in Fiji, must be nice Needless to say Hobie sent a replacement REVO, it took 2 weeks, although the Hobie HQ is only like 60-90 minutes away. I think that my delivery was based on their delivery schedule to the Los Angeles area. I think it was totally appropriate. Will be doing sea trials with some fishing monday morning. Thanks HOBIE and XTREAMLINE , you guys rock !!!!!!! MikeG |
| Author: | tigerider [ Wed Oct 31, 2007 11:33 pm ] |
| Post subject: | |
Mike, Thanks good to know, Hope your new unit is ok.. I have an 07 hull fron Xstreamline on 10-10-07 I put 6 hr's on so far so good.. Is there a way to check without removing the bolts ? |
| Author: | mg2969 [ Fri Nov 02, 2007 10:31 am ] |
| Post subject: | |
Unfortunately not really The black plastic cams covered it. We actually had to do an inverted water test to find it |
