| Hobie Livewell MOD http://www.hobie.com/au/en/forums/viewtopic.php?f=26&t=9383 |
| Author: | mg2969 [ Mon May 12, 2008 6:08 pm ] |
| Post subject: | Hobie Livewell MOD |
Sorry for the delay heres pics plus somewhat detailed instructions 2 x (1/4" )female threaded pvc elbow with mips fitting 1 3" section tubing Locate ring holding tsunami pump in place on underside Remove ring Remove pump from well and add elbow # 1 to threaded outlet (the tube thats normally inside the livewell) Place back in livewell and re-connect ring (no pic) Take section of tubing and add 2nd pvc elbow This 2nd elbow will become your new outlet I choose this fitting cuz I had it I believe a fitting is need here so water sdoesn't just spout up and you have a little control of how the water flows Take tube and connect to mips fitting on pump (DONE !!!) Adjust as necessary Hope this helps MikeG |
| Author: | Roadrunner [ Mon May 12, 2008 9:04 pm ] |
| Post subject: | |
MG, great how-to with excellent illustrations. Thanks!! |
| Author: | choopie [ Thu Oct 20, 2022 5:02 pm ] |
| Post subject: | Re: Hobie Livewell MOD |
Why can't I see the photos you uploaded? |
| Author: | plfinch [ Fri Oct 21, 2022 1:00 pm ] |
Hobie does not provide a forum solution that stores photos. This requires every forum poster to select a image hosting provider that works with this forum software. As these image hosting companies have been shut down or acquired over the years, the hosted photos have been lost or deleted. Many of these companies provided services for free and did not have viable business models. Thus, this forum is now full of broken image links. Peter |
| Author: | choopie [ Fri Oct 21, 2022 4:50 pm ] |
plfinch wrote: Hobie does not provide a forum solution that stores photos. This requires every forum poster to select a image hosting provider that works with this forum software. As these image hosting companies have been shut down or acquired over the years, the hosted photos have been lost or deleted. Many of these companies provided services for free and did not have viable business models. Thus, this forum is now full of broken image links. Peter Thank you for your kind and fast response. It would be very good to be able to see the photos that the fellow fishermen have placed in their explanations over these years... Have a nice day! |
