| 2011 A.I. Is my downhaul line rigged correctly? http://www.hobie.com/au/en/forums/viewtopic.php?f=32&t=46113 |
| Author: | mingle [ Mon Dec 31, 2012 3:23 am ] |
| Post subject: | 2011 A.I. Is my downhaul line rigged correctly? |
Hi Guys, Recently picked up a 2001 A.I. and finally assembled it (in the garden!) today. When I had the sail out I noticed that the furling line seemed a bit short (it was almost out or reach). This is how it's currently rigged: ![]() Does that look okay? And this is how much mainsheet and furling line I have when the sail is fully furled. Again, does this look about right? ![]() Being an A.I. newbie, I'd appreciated any comments or suggestions on re-rigging or adjusting the lines. Cheers, Mike. |
| Author: | Tom Kirkman [ Mon Dec 31, 2012 9:03 am ] |
| Post subject: | Re: 2011 A.I. Is my furling line rigged correctly? |
The downhaul line and furling line aren't supposed to be the same line. The downhaul line is the same type rope, but should be supplied as a short section. This may be why you don't seem to have enough furling line when the sail is fully opened. ............. |
| Author: | stringy [ Mon Dec 31, 2012 1:34 pm ] |
Mike, What Tom said! Did you get the manual with the boat? If not you can download it from the support links in the FAQ's here: viewforum.php?f=114 All the FAQ's should be required reading for any new AI owner. Especially note how the daggerboard bungee is threaded. |
| Author: | Tom Kirkman [ Mon Dec 31, 2012 2:58 pm ] |
Something else you might be interested in if you want a 3 to 1 system for both people - it can be done with the same sheet, assuming you have communication between the "crew" while underway. http://youtu.be/3EU0QV7ssNQ |
| Author: | mingle [ Tue Jan 01, 2013 2:08 am ] |
Thanks for the replies guys... I have a copy of the A.I. manual (although the copy I downloaded still refers to the 'older' style A.I. - published September 2006!). Any chance of a few photos of your setups? Also, can anyone suggest the type of knot I should use. I'm a bit hopeless in this area - I know a few fishing knots, but nothing that's of any use when rigging an A.I.! Cheers, Mike. |
| Author: | Tom Kirkman [ Tue Jan 01, 2013 6:06 am ] |
I use a bowline on the attachments points on the sail and first pulley. |
| Author: | mingle [ Fri Jan 04, 2013 6:12 am ] |
Thanks again for the replies... It's all sorted now. |
