| Sail Furler installation Notes http://www.hobie.com/au/en/forums/viewtopic.php?f=32&t=49713 |
Page 1 of 4 |
| Author: | Revo_1756 [ Mon Nov 25, 2013 8:32 am ] |
| Post subject: | Re: Sail Furler installation Notes |
I would like to add another comment on the installation of the new furling system The installation instructions call for the fairlead to be installed 5" back from the mast. This works fine if you are short and do not use the higher pedal settings. I have the revolution 13 and I am 6'2". My pedals are set to #7. I am glad I put the pedals in before I drilled for the fairlead. At 5" back from the mast on the Revolution 13 my pedals strike the furling lines. Even with the fairlead almost perpendicular to the mast the pedals strike the furling lines. I have mounted my fairlead at an angle parallel to the foot rest and in line with the last foot rest. The furling works flawlessly. The back of the pedal just presses the furling lines at full pedal stroke. For all you tall people like me please make sure your pedals do not interfere with the furling lines before you permanently mount the fairlead. I have sailed mine enough to know you still have to pedal at times and constantly pedaling into the furling lines will be a nuisance especially since they are under tension. Revo |
| Author: | JCSWFL [ Thu Nov 28, 2013 6:12 am ] |
Thanks for the post. Could you post a picture of how you rig the line that is attached to your sail? |
| Author: | flrider [ Fri Nov 29, 2013 6:58 pm ] |
JCSWFL wrote: Thanks for the post. Could you post a picture of how you rig the line that is attached to your sail? I would like to see that as well. rigging a kayak for sailing is new to me but The standard set up seems counterintuitive to me. I would think you want a set up that pulls the sail in when you pull on the control line and lets the sail out when you release the control line. Also read somewhere on this forum, and it makes perfect sense to me, that you want non-swiveling block connected aft, to avoid issues related to line twist. I just haven't seen any pictures as to how that would be installed on the Kayak. I've seen a few threads with some pretty fancy setups, including a custom made wood block in a cup holder. Very nice, but I want simple and as efficient as possible. Finally, I have the twist/stow rudder and I'm reading I need the larger rudder but can't figure out if the larger rudder works with twist and stow feature and if it's ok to leave on there when NOT sailing... It sucks being a noob |
| Author: | Revo_1756 [ Mon Dec 02, 2013 1:44 pm ] |
I am right handed so I control the main sheet with my right hand. The cleat is also on the right side inside the cockpit where I slide the main sheet through with a knot on the end so it won't fly away if you let it go. I added a pad eye behind the rear hatch with a small swivel block with a shackle head. I direct the main sheet through the block to a new pad eye on the side of the revolution just ahead of the swivel block and then another pad eye and a micro cam cleat aft of the cup holder on the gunnel. The micro cam cleat is just past the pad eye which acts like a fairlead for the cam cleat. The cam cleat locks the main sheet in place when under sail. You can buy micro cam cleats with a fairlead built in as well. This is a simple two handed method of controlling the main sheet with my right hand and furling/unfurling the sail with my left. The cam cleat eases hand fatigue from always holding tension on the main sheet, you just lock in place and go. I did add the pad eye on the side of the kayak as in the instructions for the furling kit which keeps the furling lines on the side and not across the cockpit. Attaching to the bungee pad eye the lines did cross the cockpit. Do check the need for it as Roadrunner stated according to your kayak model. Revo |
| Author: | flrider [ Mon Dec 02, 2013 7:05 pm ] |
Ok Revo. Thanks for those details. I think I am going to install the rear pad eye as well as the line off the a block gets hung up in the starboard side bungee eye pad. Larry |
| Author: | Roadrunner [ Tue Dec 03, 2013 12:58 am ] |
You can sheet the mainsheet through the existing padeye on the Revo 13 as shown here or add a new padeye as Revo has As you can see, the sail shape looks decent on both. Personally I think Revo's positioning (for the Revo 13) gives a slightly better sheeting angle and performance, but either will work for someone who doesn't want to add another padeye. I run the mainsheet forward from that point without additional routing to another swivel block set forward like this: ![]() In essence, now you can pull back on the sail rather forward to control it for a more natural position. You may have to use a longer mainsheet on some models. Note the cam cleat to secure the sheet as Revo describes (locations can vary according to circumstance and boat). For the Revos, Sport and Adventure I don't recommend them unless the wind is light or with Sidekicks because these boats respond quickly to gusts and you need to be ready to dump wind instantly on occasion or increase the risk of capsize. The beamier boats have a little more stability and can better benefit from the cleat. You can always add the cleat later if appropriate. Here's an old post discussing rigging and a big caveat regarding the use of swivel blocks. It also shows detachable sheeting and the obvious benefits for easy stowing and raising the sail. viewtopic.php?f=32&t=47998&p=213539&hilit=#p213539 flrider wrote: The illustrated instructions seem to show the lines loosely hanging on the outside of the kayak. Your install shows the lines on the inside of the kayak. Can you share your reasoning? In reality there is tension on the furler provided by the bungee so the lines run straight point to point. Since I anchored the bungee to the existing cargo padeye, that's just how they ended up -- works fine on this application. You can route them outboard but I don't see an advantage. As shown, they are out of the way, easy to reach and the installation is very simple and easily portable. The outboard sides are free to take a paddle or stowed sail without interference. If you don't don't like it after trying it out, it's easy enough to redirect them later. |
| Author: | flrider [ Tue Dec 03, 2013 7:14 am ] |
flrider wrote: The illustrated instructions seem to show the lines loosely hanging on the outside of the kayak. Your install shows the lines on the inside of the kayak. Can you share your reasoning? In reality there is tension on the furler provided by the bungee so the lines run straight point to point. Since I anchored the bungee to the existing cargo padeye, that's just how they ended up -- works fine on this application. You can route them outboard but I don't see an advantage. As shown, they are out of the way, easy to reach and the installation is very simple and easily portable. The outboard sides are free to take a paddle or stowed sail without interference. If you don't don't like it after trying it out, it's easy enough to redirect them later. Yes, I found that to be true as well. The location of the guide thingy (don't know what it's called) on mine and the bungee connect not the rear storage bungee tab, put my line just on the outside edge. Pictures to come... |
| Author: | dennyf [ Thu Dec 05, 2013 8:29 pm ] |
Revo, you said "This is a simple two handed method of controlling the main sheet with my right hand and furling/unfurling the sail with my left. The cam cleat eases hand fatigue from always holding tension on the main sheet, you just lock in place and go." Did you mount the furling lines on the left side? I'm just fixing to mount my fairlead and I like the idea of controlling the furling with my left hand and the main sheet with my right. The instructions show it on the the furling lines on the right but that's not set in stone. Thanks Denny |
| Author: | Revo_1756 [ Fri Dec 06, 2013 1:33 pm ] |
Yes I mounted mine on the left. The fairlead will work on either side. I installed my anchor trolley on the right side of my new hull as it is in the picture. The furling line would be a tangle issue if it was on the same side as the anchor trolley. Revo |
| Author: | dennyf [ Sat Dec 07, 2013 1:15 pm ] |
Well I installed my furling kit and I learned a few things. First I wanted to make sure that the pedals didn’t hit the furling lines so I put the mirage drive on position 7 and tested the location of the fairlead. I ended up with it almost directly across from the mast. Not the best angle for pulling the lines but I didn’t want to have the pedals hit either. Then I took Revo’s lead and mounted the furler on the left or steering side, which when not using the pad eye provided interferes with the steering lever. I went ahead and mounted the pad eye on the side of the kayak; by the way there is no way to reach the inside of the kayak to mount the pad eye on my 2014 Outback. So I used rivets instead of screws. Also when mounted the fairlead make sure there is clearance for the nut and washer if you are close to a sharp edge. The fairlead has two steps for the screws the front one doesn’t give much length for the screw to stick out, but the rear one has plenty of length when the screw is inserted. I ended up having to grind a flat on one washer to get it to clear the edge I mounted it near. Plus it was the one that didn’t stick out very far which made getting the nut and washer on a pain. To really get the line out of the cockpit area you need a second fairlead. But I think it will work OK the way it is. I also had to untie the furling line to reposition one of the balls on the other side of the knot and I put the other knot in a different location. You just have to play with it to get them in the position you need. DF I took pictures, but not have a site to host them. I tried pasting but it didn't work. |
| Author: | Revo_1756 [ Tue Dec 10, 2013 12:39 pm ] |
dennyf. As you can see in my quote below from above and even in Roadrunners pictures the furling line ends up perpendicular to the mast for us tall people at #7 setting. I had to adjust the balls too. It definitely is a one size fits all but with adjustments per model and type of kayak. Revo Revo_1756 wrote: I would like to add another comment on the installation of the new furling system
| Page 1 of 4 | All times are UTC - 8 hours [ DST ] |
