| Nut found in hull http://www.hobie.com/au/en/forums/viewtopic.php?f=32&t=61445 |
| Author: | slygizos [ Sat Sep 02, 2017 4:01 am ] |
| Post subject: | Nut found in hull |
Hello. I just found a nut in the hull of my 2014 Adventure Island. Any ideas from where this nut might fall off? Thanks in advance for your replies. ![]() ![]() Sent from my SM-N910C using Tapatalk |
| Author: | stobbo [ Sat Sep 02, 2017 3:06 pm ] |
| Post subject: | Re: Nut found in hull |
I think the most likely source is one of the brackets that attach the AI mast receiver bottlescrew braces. I remember (having taken my very early AI apart to replace a hull) that there are two braces, one either side that go from the bottom of the mast receiver to the aka bar in some way where they locate onto a threaded rod with a nut to hold them in situ, but not having my boat available to look at I am having difficulty remembering the exact setup. Either way, since most of the deck fittings do not penetrate the hull but attach via moulded-in inserts, what you need to identify is a fitting where there would be a screw-thread protruding into the hull or one that is part of a fitting already inside the hull. I suspect that the braces aforementioned are one of your first places to look. Hope this helps & please report back! |
| Author: | Roadrunner [ Sat Sep 02, 2017 4:41 pm ] |
There is a possibility it is an extra -- dropped in the hull during assembly and wasn't retrived. This has happened to me. |
| Author: | slygizos [ Tue Sep 05, 2017 12:15 am ] |
Hello guys. Thank you very much for your replies. I checked everything inside the hull and no nut is missing. So maybe there is a left over or something. The funny part is that I found the nut after 3 years that I own the AI. Lol. Sent from my SM-N910C using Tapatalk |
| Author: | stobbo [ Tue Sep 05, 2017 9:10 pm ] |
Mighta sneaked in through those rudder cable tubes... |
| Author: | slygizos [ Wed Sep 06, 2017 12:08 am ] |
stobbo wrote: Mighta sneaked in through those rudder cable tubes... lolololololololol |
