| Rudder Rake http://www.hobie.com/au/en/forums/viewtopic.php?f=34&t=4966 |
| Author: | REDSHIFT [ Fri Sep 22, 2006 9:03 pm ] |
| Post subject: | Rudder Rake |
Need some advice on rudder rake adjustments; I have "major league" lee helm (worst on port tack) and have adjusted the screws as far back(aft) as mechanically possible and have adjusted mast rake from 4 up, to all the way down on the shroud adjuster. Only thing not tried is swapping the rudder blades-have swapped the daggers. |
| Author: | hobie1616 [ Fri Sep 22, 2006 11:37 pm ] |
| Post subject: | |
When you adjusted the screws in the lower castings did you also move the pieces inside the upper tiller castings that latch on the cams? The angle won't change unless you adjust both. |
| Author: | REDSHIFT [ Sat Sep 23, 2006 9:09 am ] |
| Post subject: | |
The latch plates have been adjusted for each positioning of the stop screw |
| Author: | Hammond [ Mon Sep 25, 2006 12:35 pm ] |
| Post subject: | |
Something is not right. Do you have a chainplate adjuster on top of your forestay? If not, this may solve your problem. You may need to buy new shrouds because the old ones you have sound too long. If your wires are this old, they should be replaced anyway. My rudders are pulled under the boat so that the tips are in line with the transoms. Also, if you have different tiller load on each tack, then your rudders are raked different or drilled different. Take them both off the boat and lay them on top of each other and see if the holes are the same. Mark them before you take them off. If you have good balence on one tack, then the leeward rudder is the one you want to measure off of since it is the loaded rudder. |
