| Mast rotation and cascading downhaul http://www.hobie.com/au/en/forums/viewtopic.php?f=34&t=62652 |
| Author: | Aussie7496 [ Mon May 07, 2018 8:09 am ] |
| Post subject: | Mast rotation and cascading downhaul |
Two questions: Does anyone have any pictures/diagrams of for setting up the cascading downhaul system? Is there anything to be aware of when moving the rotator above the boom? |
| Author: | Jbernier [ Mon May 07, 2018 8:49 am ] |
| Post subject: | Re: Mast rotation and cascading downhaul |
You can see the systems from the Wildcat in the parts guide online here:https://static.hobiecat.com/digital_assets/wildcat-part-guide-201705.pdf?_ga=2.245532996.1947164500.1525706207-46684098.1524004451 (page 23 has a very clear diagram) - you can rig a H20 the same. Just need a couple of extra pulleys and cleats on the side of the mast. |
| Author: | Aussie7496 [ Tue May 08, 2018 11:20 am ] |
Is there a specific distance that those top blocks need to be mounted up the mast? |
| Author: | Jbernier [ Tue May 08, 2018 3:00 pm ] |
Aussie7496 wrote: Is there a specific distance that those top blocks need to be mounted up the mast? They aren't mounted on the mast - they're attached to the foot of the main via a shackle - they go down with the sail as it comes down. Look at the diagram. It's very easy to use - you pre-load the double blocks with the larger rope that going into the cleats on either side of the mast. that is a 16:1 system. Works awesome on the Wild Cat and Tiger. I've never rigged one on an H20 but I'm sure other's can chime in. |
| Author: | MBounds [ Thu Jun 07, 2018 10:43 am ] |
Class rules prevent more than an 8:1 purchase on the downhaul: (Hobie 20 Class Rules) Quote: 3.2 Mainsail downhaul purchase shall not exceed
8:1 purchase. The downhaul line must cleat on the mast or foot of the sail and may be rigged in any manner. "Cam" cleats are legal. |
