| Spinnaker Blunt End Cap http://www.hobie.com/au/en/forums/viewtopic.php?f=37&t=10344 |
| Author: | OLD SCHOOL 18 [ Tue Aug 12, 2008 5:06 pm ] |
| Post subject: | Spinnaker Blunt End Cap |
12.2 Only bowsprits supplied by a HOBIE CAT COMPANY are class legal. The bowsprit shall have a blunt end cap fitted. The bowsprit shall be fixed on the longitudinal centre line of the boat as provided by the manufacturer. Supporting wires/lines may be shortened, lengthened, mounted and/or rigged in any manner. Additional blocks/cleats for spinnaker running gear and jib luff control as well as snuffer type systems may be mounted on the bowsprit. So, wanting to do this right with NA's only a few days away, I looked it up. What is a blunt end cap anyway? http://www.urbandictionary.com/define.php?term=blunt How am I going to get one of those through customs? |
| Author: | Sail Revolution [ Tue Aug 12, 2008 6:02 pm ] |
| Post subject: | |
I have it from a solid source that you can pick up one of those when you get over the border, eh!. |
| Author: | MBounds [ Tue Aug 12, 2008 7:52 pm ] |
| Post subject: | |
The stock end cap as supplied by Hobie Cat is a "blunt end cap" for the purposes of the class rule. The rule is meant to prevent "spearing" injuries caused by a cut away pole. |
| Author: | Karl Brogger [ Tue Aug 12, 2008 9:11 pm ] |
| Post subject: | |
I lost mine. Same with the boom. I should replace those, it just looks rugged with out them. Like it should be parked outside of a rusting trailer home next to a 84' Camaro in primer grey. |
| Author: | BLR_0719 [ Tue Aug 12, 2008 9:58 pm ] |
| Post subject: | |
Tape it inside the spin pole, then cover it with the blunt cap |
| Author: | Claus [ Wed Aug 13, 2008 7:13 am ] |
| Post subject: | |
The rules dont say it has to be the original HC blunt cap, so probably a piece of cork should do, but you cant smoke it. |
| Author: | hobie18rich [ Tue Apr 21, 2009 11:04 am ] |
| Post subject: | Re: Spinnaker Blunt End Cap |
Is this rule still applicable under the new ISAF rules? I wanted to run a open cap that allowes the tack to run out the end of the pole. It is a rounded aluminum piece similar to the Infusion. Will this be class legal? |
