| Water in the hull on the Bravo http://www.hobie.com/au/en/forums/viewtopic.php?f=42&t=7000 |
| Author: | Bruce8989 [ Tue Jun 12, 2007 1:34 pm ] |
| Post subject: | Water in the hull on the Bravo |
After several hours of sailing I end up with several cups (more than I think should be there) worth of water in the starboard hull. Anyone have any idea where that water could be coming from? Drain plugs both seat well and are tight. I seriously doubt that much water could be coming over either of the front or rear storage compartments, I"m not sure if those seams drain into the hulls? Although I do get the bow leeward carrying handles into the water when hiked out.. it doesn't seem as those could be leaking? Where else could it come from? I don't think these hulls 'breathe' like the fiberglass boats do they? Any ideas? |
| Author: | mmiller [ Tue Jun 12, 2007 1:44 pm ] |
| Post subject: | Leak? |
You can do a leak test as shown in this forums FAQ (top - topic). Check all fittings. Check the inboard side of the hulls. There is a small cap adheared over a vent. Maybe loose? |
