| rivet size to fix wings? http://www.hobie.com/au/en/forums/viewtopic.php?f=45&t=59851 |
| Author: | Ludo Frenchie [ Sun Jan 29, 2017 2:51 pm ] |
| Post subject: | rivet size to fix wings? |
Hello, the wings of my 21 SE are loose at the junction in between the main tube, and the horizontal tubes. I do not beleive they could brake soon, but still would like to fix this. Does anyone know the rivet size I need to use? I suppose Stainless ? Thank you |
| Author: | Ludo Frenchie [ Wed Mar 01, 2017 8:01 am ] |
| Post subject: | Re: rivet size to fix wings? |
hello again, I could dismantle a "branch": the original rivets seem to be aluminium, watertight. I got some 4,8mm stainless rivets, but they seem a bit too loose in the holes. should I use stainless? (on aluminium....) What is the HC reference ? seemsPN 8010121 would be the one, but there are 4,8mm too..? merci |
| Author: | Bill 404 [ Wed Mar 01, 2017 8:20 am ] |
You need to use those stainless steel rivet castings with silicon first than place the stainless rivets 3/16" X maybe 7/8 grip range into that casting to aid in keeping water out. These casting pieces will take up that extra room you find in the drilled hole size. Good luck.....spring will be here soon! Part number 8011291 may be the rivet "caps" or "casting" this part is a pocket like item for the rivet to slide into. |
| Author: | mmiller [ Wed Mar 01, 2017 9:44 am ] |
Stainless for sure. 8010131 RIVET POP 3/16x3/8 PH-SS 8011291 RIVET CAP http://www.hobiecat.com/dealers/ |
| Author: | Ludo Frenchie [ Sun Mar 05, 2017 7:24 am ] |
thank you Matt and Bill: the river cap was the trick, I could source some at the Hobie shop in Hyere, South France (nice guys by the way). |
