| Motor for Sport Cruiser http://www.hobie.com/au/en/forums/viewtopic.php?f=45&t=62877 |
| Author: | perryparks [ Sun Jun 03, 2018 3:09 pm ] |
| Post subject: | Motor for Sport Cruiser |
Would like to know what brand, size and shaft length of motor owners of SC 21 suggest. |
| Author: | speed633 [ Mon Jun 04, 2018 6:54 am ] |
| Post subject: | Re: Motor for Sport Cruiser |
Power: 1HP is enough... 2HP is Plenty. You will have a very tough time finding a gas motor that is underpowered. Brand: I have a Suzuki DT2. It has survived more than any motor should, and still starts on the first pull even with 1.5yr old gas in the tank... Length: mine is a little short, If the crew moves forward on the boat the motor comes out of the water. If the crew stays back it works fine. A long shaft might be heavier, and harder to tilt. You can go electric, but your range and power will be limited. The range is the bigger issue here. |
| Author: | kevinbatchelor [ Tue Jun 05, 2018 7:36 pm ] |
Honda 2.3 horsepower 30 lb motor just got a brand new one at write it out this weekend at work great it would push the boat about 6 miles an hour down wind and five miles an hour up wind and that was with 3 adults and 6 kids on it |
| Author: | perryparks [ Wed Jun 06, 2018 6:42 pm ] |
Kevin, what length shaft did you get? |
| Author: | kevinbatchelor [ Tue Jun 12, 2018 9:41 pm ] |
Its the short shaft |
| Author: | drcam1 [ Wed Jun 13, 2018 5:49 am ] |
I have an ANCIENT Mariner 2hp. 26 inch shaft. (35 inches total length with integral tank). Only time I have ever had issues was driving into heavy chop, prop would occasionally pop out. I am able to fit inside onboard storage lockers. |
