| Pump http://www.hobie.com/au/en/forums/viewtopic.php?f=47&t=12092 |
| Author: | SteveLIBS [ Sat Mar 28, 2009 2:38 pm ] |
| Post subject: | Pump |
Whats the process for greasing or lubing the pump? Mine is getting noisy. |
| Author: | WinterParkKris [ Mon Mar 30, 2009 9:22 am ] |
| Post subject: | |
I'd try cleaning the shaft with CLR or Lime Away first. If that doesn't work, I am sure that graphite would probably be a good lubricant for it. |
| Author: | sunjammers [ Mon Mar 30, 2009 4:21 pm ] |
| Post subject: | |
a shot with some dry silicon should do the trick. |
| Author: | papajohn [ Fri Dec 04, 2009 11:24 am ] |
| Post subject: | Re: Pump |
My pump was extremely loud and difficult to operate after 8 inflates. I took it apart to find that it was filled with dirt and grime -- not sure how that happened. I cleaned the head of the shaft and the inside of the barrel, then added some silicone grease to the shaft head. It's like new again. John |
