| Pedal Play? http://www.hobie.com/au/en/forums/viewtopic.php?f=47&t=42390 |
| Author: | dboyd101 [ Fri Apr 27, 2012 10:07 am ] |
| Post subject: | Pedal Play? |
I have a little (very little) play in the pedal. I was curious if this normal? It slides slightly back and forth leaving about 1/8" of gap between the pedal arm and the pedal exposing a silver bar that holds the pedal to the pedal arm. Is this normal? Should I be concerned? Any tips/advice here to get that sucker tight to the arm will help. Thanks! |
| Author: | Jbernier [ Fri Apr 27, 2012 10:21 am ] |
| Post subject: | Re: Pedal Play? |
You can pop the end cap off (using a flat head screwdriver) and use a socket to tighten the nut that holds the pedal back on tight. They do have a slight amount of play built in from the factor, but 1/8" seems high... it should be about half of that. |
| Author: | dboyd101 [ Fri Apr 27, 2012 1:19 pm ] |
Awesome.. thanks for the very quick feedback! |
