| Larger Rudder for i-Series http://www.hobie.com/au/en/forums/viewtopic.php?f=47&t=49269 |
Page 1 of 2 |
| Author: | mmiller [ Wed Sep 11, 2013 11:50 am ] |
| Post subject: | Larger Rudder for i-Series |
Larger Rudder for i-Series We have located a number of the original larger rudder that can be used on i-Series kayaks. Stocked as #81397101 i / QUEST - RUDDER BLADE - LARGE / TWIST-N-STOW ![]() This rudder does not require modification for use on i-Series or Quest Twist and Stow rudder systems. |
| Author: | TRU [ Mon Sep 16, 2013 1:57 pm ] |
| Post subject: | Re: Larger Rudder for i-Series |
How can I get my hands on one? My dealer called and no me seemed to know about these? TRU ... |
| Author: | mmiller [ Mon Sep 16, 2013 4:51 pm ] |
Quote: stocked as #81397101 i / QUEST - RUDDER BLADE - LARGE / TWIST-N-STOW
Quote: stocked as #81397101 i / QUEST - RUDDER BLADE - LARGE / TWIST-N-STOW Your dealer just needs to place an order. |
| Author: | TRU [ Mon Sep 16, 2013 5:30 pm ] |
Thanx. They mentioned they called today and it sounds like there was confusion on ordering it. I will follow up with them to see if they can order one for me. Thanx TRU ... |
| Author: | TRU [ Wed Sep 18, 2013 2:02 pm ] |
Follow-up .... One has been ordered. Thanx! TRU ... |
| Author: | mmiller [ Wed Sep 18, 2013 2:42 pm ] |
My staff was confused. Going by memory instead of what is in the system. Sorry about that! |
| Author: | TRU [ Wed Sep 18, 2013 3:16 pm ] |
No problem ... It just gave me the opportunity to add a few more things to the order TRU ... |
| Author: | TRU [ Sat Oct 05, 2013 11:49 am ] |
I installed the rudder on my i12s this past week and it makes a huge difference! Loving it! |
| Author: | frankfp [ Tue Oct 08, 2013 9:21 am ] |
TRU. I just ordered a large rudder for my Hobie i12, you said it made a Hugh difference in handling, could you please explain more the difference it made for you in handling. Thanks you. ----Frank |
| Author: | TRU [ Tue Oct 08, 2013 6:15 pm ] |
Frank, putting the sailing rudder on made the i12s much more responsive in turning. It was easier and seems to make a tighter turning radius too. I don't know why, but it also seems to hold a straight course better. I don't have to fine tune it as much. This doesn't make as much sense to me as the easier turns do. As far as using it with the sail, I am a COMPLETE novice with sailing. I tried the sail with the regular rudder and there were times it wouldn't even turn the kayak. The regular rudder just wasn't big enough to bite into the water to help me turn. I am still having trouble with the sail, but not with turning anymore. The sailing rudder is a little harder (heavier) to raise and lower from the cockpit. It's doable, but it does take more effort. I also recently bought the ST Turbo blades and that has also made a difference as well. I can go much faster, but what I really like it for is that I can pedal at a slower comfortable pace and still be moving at a decent clip. Hope that helps! TRU ... |
| Author: | mmiller [ Wed Oct 09, 2013 7:57 am ] |
It's more surface area in the water. Like traction... Cleats vs tennis shoes playing football on wet grass Tires with treads vs bald while driving in the rain The smaller rudder works, just doesn't respond to turns as easily as the larger blade. |
| Author: | frankfp [ Wed Oct 09, 2013 8:17 am ] |
Thanks Matt and TRU, I will see how the large rudder works with my new Watersnake 24lb. Trolling motor in late October in Florida. Take care-----Frank |
| Author: | gleeloyd [ Tue Apr 08, 2014 5:45 am ] |
Matt, Before I ask my dealer to order, are these still available? If not available, is there an alternative? Thanks! |
| Author: | Jbernier [ Tue Apr 08, 2014 9:46 am ] |
gleeloyd wrote: Matt, Before I ask my dealer to order, are these still available? If not available, is there an alternative? Thanks! Yes - they are available, in stock. |
