| 2015 AI Mods. http://www.hobie.com/au/en/forums/viewtopic.php?f=69&t=54432 |
| Author: | Drewyaker [ Thu Apr 16, 2015 9:26 am ] |
| Post subject: | Re: 2015 AI Mods. |
All looks very nice, but do you have a backing plate to help support the Yakattack rail because wind gust can impose a lot of pull on the cam cleat. |
| Author: | walt [ Sat Apr 18, 2015 7:29 am ] |
just an opinion.. I think those rails would be fine without a backing plate as the force from the sheet and furler would try and sheer the screws rather than pull them out. Plus there are numerous scews. If the force is trying to pull the screws out (I dont think it is in this particular case).. best use a backing plate. |
| Author: | Seagull [ Sat Apr 18, 2015 7:40 am ] |
Always use a backing plate. Always. There is never a reason to not use a backing plate. I have seen cleats ripped off powerboats because "all I need is a screw". At the very least use a nut and bolt and throw a large washer under the gunwale. Fiberglass is much stronger than plastic too. My first mod is going to be designed today. I want to put on a 2.5 hp kicker. |
| Author: | PeteCress [ Sat Mar 19, 2016 1:12 pm ] |
Hogman wrote: Changed the sheet and furling line cam cleats so ropes are easier to manage and added a Ronstan cheek block ... The new blocks are all 29mm, right?
