| Island Trampoline Tightening http://www.hobie.com/au/en/forums/viewtopic.php?f=70&t=45530 |
| Author: | Tom Kirkman [ Fri Nov 02, 2012 6:54 pm ] |
| Post subject: | Island Trampoline Tightening |
Just in case I'm missing something - I tried installing the tramps on my new Tandem Island. No way I can see to get them tight. With the buckles run up all the way, there is still a good couple inches of sag in the tramps. Not tight at all. Barely snug, if that. Am I missing something? |
| Author: | stringy [ Fri Nov 02, 2012 7:56 pm ] |
| Post subject: | Re: Island Trampoline Tightening |
They are TI tramps? AI tramps won't tighten enough on the TI. |
| Author: | Tom Kirkman [ Sat Nov 03, 2012 7:26 am ] |
I think you just answered my question! Thanks. |
| Author: | stringy [ Sat Nov 03, 2012 2:44 pm ] |
I did use AI tramps on the TI when I first got it. I had some success with pvc pipes as spacers but as the weather warmed they would eventually slip when the tramps stretched. Pool noodle worked OK: viewtopic.php?f=69&t=26107&p=133851 |
| Author: | Tom Kirkman [ Sat Nov 03, 2012 3:08 pm ] |
Apparently the TI tramps will fit both, if it's a little shorter then the straps could be lengthened to work on the AI. But not the other way around, I guess. You can only take up so much slack. Thanks. |
