| Mast Wobble No More http://www.hobie.com/au/en/forums/viewtopic.php?f=70&t=46369 |
| Author: | Tom Kirkman [ Sun Jan 27, 2013 5:43 pm ] |
| Post subject: | Mast Wobble No More |
At first I thought it might be my forward Aka slipping, but that seemed impossible due to how it mounts. A rough water day with the sail furled exposed the problem. http://www.youtube.com/watch?v=ldkMmaGP ... e=youtu.be I took a section of nylon tubing and bored the inside... ![]() Turned the outside... ![]() To the appropriate sizes. Then epoxied the extremely thin collar to the mast base and fine tuned the fit. ![]() It's very clean now. Extremely little wobble. To be honest, it wasn't really hurting anything, but the "CLUNK" was a little disconcerting. Now it slips into place easily, but no more "clunk." |
| Author: | Deepbluesilence [ Mon Jan 28, 2013 3:55 pm ] |
| Post subject: | Re: Mast Wobble No More |
Well done Tom....nice to see a fellow rod builder on the board I would think even just that little bit of slop puts more strain on things.. So what kind of buttwrap are you guna do on that thing? -Jeff |
| Author: | Tom Kirkman [ Mon Jan 28, 2013 4:31 pm ] |
If it wouldn't be covered up by the mast.... Tape would probably take up the slop as well, but being somewhat soft it may not provide a good surface for the roller bearing to work against. Something I thought about - a wrap of D thread coated with maybe 5 applications of Permagloss would take up about 1mm and offer a rock hard surface for the bearings to roll on. That might be a simpler way to do this. |
| Author: | Deepbluesilence [ Mon Jan 28, 2013 5:06 pm ] |
Yea definitly and the adhesion would be better with epoxy on epoxy.....having a constant supply of epoxy on hand is always helpful |
| Author: | Tom Kirkman [ Mon Jan 28, 2013 5:45 pm ] |
PG is much, much harder than any epoxy. Thus the bearings should turn nicely on it. |
| Author: | Deepbluesilence [ Mon Jan 28, 2013 6:36 pm ] |
Looks like good stuff, always had good luck with u-40 products.....probly stick with epoxy if i do it tho free is always better |
| Author: | tjcouch [ Mon Jan 28, 2013 7:49 pm ] |
BEST LINE EVER, " I don't like it, and I'm going to fix it.". Well done, sir. |
| Author: | stringy [ Tue Jan 29, 2013 4:29 am ] |
Tom Kirkman wrote: Something I thought about - a wrap of D thread coated with maybe 5 applications of Permagloss would take up about 1mm and offer a rock hard surface for the bearings to roll on. That might be a simpler way to do this. Tom, I'm interested in this "D thread". What is it exactly? I'm looking for a better way to build up the TI's furling drum taper so that it fits the AI's mast tube. Great workshop setup BTW! |
| Author: | Tom Kirkman [ Tue Jan 29, 2013 5:46 am ] |
Nylon rod guide wrapping thread in size D. This allows you to keep the drum concentric without having to do any machine work. The coating is an ultra-hard aerospace moisture curing urethane developed by a former Boeing chemist, although there are likely others that would work equally well. |
| Author: | stringy [ Thu Jan 31, 2013 4:11 am ] |
OK gotcha. Thanks for that. |
