| Adding a Jib to the Ti http://www.hobie.com/au/en/forums/viewtopic.php?f=70&t=50219 |
| Author: | John_h [ Fri Jan 17, 2014 6:51 pm ] |
| Post subject: | Re: Adding a Jib to the Ti |
I haven't had any issues with the square tube bending on my AI with my jib that is way too big. I think I would flip the boat before they bent. |
| Author: | NOHUHU [ Fri Jan 17, 2014 8:16 pm ] |
I like your approach using the tracks. But perhaps an exoskeleton in overkill? I would think that a proper backing plate would handle a small jib. Or plates, if you want to add a short sprit. |
| Author: | Chopcat [ Sun Jan 19, 2014 12:43 pm ] |
NOHUHU wrote: I like your approach using the tracks. But perhaps an exoskeleton in overkill? I would think that a proper backing plate would handle a small jib. Or plates, if you want to add a short sprit. Yes you are right. i have just trailed the boat back and at first look the bow is straight enough to just add a tube to each side. I dont think it is essential that it connects to the AKA itself so I will press on with my yackattack demountable idea as soon as I can find some tube. CC |
| Author: | ppicker [ Sun Jan 19, 2014 1:22 pm ] |
ALuminum cuts well on C02 lasers, I cut it all the time. Alternatively water jet will cut it. www.peridotcorp.com |
| Author: | Chopcat [ Mon Jan 20, 2014 12:41 am ] |
ppicker wrote: ALuminum cuts well on C02 lasers, I cut it all the time. Alternatively water jet will cut it. http://www.peridotcorp.com Yes. I havnt access to one that will do it. What sort of cost would you charge for the topper at bthe head of the post in say 6mm Ali to the UK? Cc |
Chopcat wrote: ppicker wrote: ALuminum cuts well on C02 lasers, I cut it all the time. Alternatively water jet will cut it. http://www.peridotcorp.com Yes. I havnt access to one that will do it. What sort of cost would you charge for the topper at bthe head of the post in say 6mm Ali to the UK? Overall lenght 900mm Cc |
| Author: | fusioneng [ Mon Jan 20, 2014 7:08 am ] |
Chopcat / john: The only reason for the bow brace is to give you something else to connect to besides the bow pad eye, and help re-enforce the bow a little to prevent the front hatch from leaking like a siv from the up and down bending motion of the bow with a jib or spinnaker mounted. Myself and others only attached to the aka bar because it's the strongest point on the hull. I'm sure yak attack bars mounted just in front of the brace will work just as well. Extra cross bracing is probably overkill. Even with no jib at all the bow bends up and down and water leaks into the hatch as you go thru the waves, the brace pretty much stops the leaking. On the mast topper lighter is better (weight aloft), my current mast topper is under two lbs. johns stainless topper will be plenty strong as is. I only bent mine by doing very stupid stuff like trying to fly 260 sq ft of sail in 25 mph winds ( not a good idea). My mild steel topper only bent because I was doing almost 20 mph, hit a gust and a big wave at the same time and the boat dove and stopped ( dumb thing to do). With johns topper if he is worried about it bending, a piece of spectra string strung from front to back and over the top in the center, would strengthen it more than enough for pretty much any thing ( I recomend using lightweight nylon (stretchy) rope for the rear stay line, it's only there to prevent the topper from spinning and to protect the mast holder in the bottom of the hull ( that 1/4 inch stud) from being over stressed on a downwind run in higher winds (mostly with spinnakers). Pretty much any design will work, again no reason to over design. If running just a jib that rear stay is less important ( unless it's frickken huge (lol)). Also the TI and AI are different boats. The mast on the TI is mounted too far forward on the TI kind of making the bow sprit needed if you want to run both a jib and a spin, and might be unnecessary on an AI (because the mast is further back). I would love to see video of these in action. Good luck Bob |
| Author: | NOHUHU [ Mon Jan 20, 2014 7:52 pm ] |
Hadn't really thought much about the twistoflex action on the front hatch seal. Good to consider this and have a 2nd inner seal to ease the slurping effect. I've noticed that hulls vary quite a bit in thickness and rigidity from boat to boat. Some AIs could require more bracing than others. The AI bow takes more of a beating them the TI, due to its shorter Amas, but the TI experiences massive flex from the larger sail. On either boat I would think that the jib cleats would be the weakest point. You should use good hardware and mount it well. How are you planning to do this? |
| Author: | Chopcat [ Tue Jan 21, 2014 11:23 am ] |
NOHUHU wrote: Hadn't really thought much about the twistoflex action on the front hatch seal. Good to consider this and have a 2nd inner seal to ease the slurping effect. I've noticed that hulls vary quite a bit in thickness and rigidity from boat to boat. Some AIs could require more bracing than others. The AI bow takes more of a beating them the TI, due to its shorter Amas, but the TI experiences massive flex from the larger sail. On either boat I would think that the jib cleats would be the weakest point. You should use good hardware and mount it well. How are you planning to do this? I have upgraded my main to a spinlock swivel cleat and was proposing to use these with some backing plates mounted on the tops of the hull for the jib lines in the area where the cleats for the spray skirts are. The roller furler line will go to the left hand side of the mast with a cleat mounted on the AKA rail. (if that makes sense) I agree the cross braces are overkill looking at the boat now so i will go with a tube either side and see ! CC |
| Author: | NOHUHU [ Tue Jan 21, 2014 2:03 pm ] |
I like those swivel cleats for the jib lines! The furling line should only require a micro cam. Anyone considered placing their jib cleats just outside the knuckle joints on the Akas? |
| Author: | Chopcat [ Wed Jan 22, 2014 12:05 am ] |
The problem is that with the swivel cleats you need a flat base to mount them on. I made one up for the main sheet using the plastic adapter that came with the original and an aluminium plate. So it could work. Then there is the complication of the tramps, where i suppose you could cut a hole in them. It mightbe a nicer position for them. I will think about it. Cc |
| Author: | Chopcat [ Mon Jan 27, 2014 1:15 am ] |
Chopcat wrote: The problem is that with the swivel cleats you need a flat base to mount them on. I made one up for the main sheet using the plastic adapter that came with the original and an aluminium plate. So it could work. Then there is the complication of the tramps, where i suppose you could cut a hole in them. It mightbe a nicer position for them. I will think about it. Cc I have had a thought of using a couple of railblaza mounts on the akas which are redundant due to the theft of my rod mounts. If i can make up an adapter to take the spinlock swivel cleats. Or perhaps just screw them on to the star port. CC |
