| reverse furling direction on 2017 TI http://www.hobie.com/au/en/forums/viewtopic.php?f=70&t=61494 |
| Author: | idaho brit [ Sat Sep 09, 2017 1:03 pm ] |
| Post subject: | reverse furling direction on 2017 TI |
I would like to switch the furling line to the port side. My 2017 TI has pre drilled holes on the Aka where I was going to attach a cheek block to redirect the furling line. I found that the spacing is too close for the cheek block, the spacing is the same as the cam cleat, so I was thinking to move the existing cam cleat over to the left to avoid drilling and threading another hole in the Aka. This means that the angle of the line to the cleat would not be a fair angle. If I reversed the furling direction the line would come off the front of the spool giving the same angle as the original and a fair run to the cleat. My question: Is there any reason that would not work, or would damage the sail by furling it on the mast in the opposite direction to the standard setup? |
| Author: | LSYak [ Sun Sep 10, 2017 5:11 pm ] |
| Post subject: | Re: reverse furling direction on 2017 TI |
Hi Brit, There is no reason not to run the furling line down the port side. Many seem to do it. Rather than moving the cam cleat, I would look at screwing a mounting plate first to the pre-drilled holes on the aka and attaching the cheek block to the mounting plate. The mounting plate can be something as simple as cutting and drilling a old plastic cutting board which can be painted black and wouldn't look out of place. I've seen others on the forum use plastic cutting boards as mounting plates so it should work. Cheers John |
| Author: | idaho brit [ Tue Sep 12, 2017 10:55 am ] |
Thanks John. Thats not a bad idea, I might try that. I overthink things sometimes. |
| Author: | LSYak [ Tue Sep 12, 2017 8:43 pm ] |
Unfortunately I sometimes I tend to "under think" Cheers John |
