| New Rudder Pin - Now Available http://www.hobie.com/au/en/forums/viewtopic.php?f=71&t=14216 |
Page 1 of 2 |
| Author: | mmiller [ Mon Aug 31, 2009 9:57 am ] |
| Post subject: | New Rudder Pin - Now Available |
New Rudder Pin - Now Available ![]() Note upper pin is new - Gray... lower image is the original black pin. We completed testing and have received production of the new pin made from a different material and color. This is stiffer and stronger than the pins tested from the last few production runs (which had shown some variance from the original specs). This is not a retrofit issue or a free upgrade. Simply order a new pin using the original part number: 81394001 RUDDER PIN, TWIST N' STOW RDR Our parts department is only stocking the new version. 2010 AIs will come with these new pins. Other models will be using the black pins until the stock runs out. Dealers were informed of the change last week. |
| Author: | Aledal [ Mon Aug 31, 2009 11:03 am ] |
| Post subject: | Re: New Rudder Pin - Now Available |
Okay-thanks Pirate and Matt. I still have my original pin in place. But will switch to a brass pin soon. I`m on vacation next week for a month. And will (hopefully) be sailing in hurricane winds over here on Long Island. I`m not worried about ripping the transom(sp) off in shallow waters...I`ll just un cleat. I cant believe no one has answered this post of posts. In the words of Roger Waters(no pun intended) Is there anybody out there? |
| Author: | mickeymouse [ Tue Sep 01, 2009 5:07 pm ] |
Y'all very quiet I have never broken a pin ....YET!! But if I ever do, I'll wish I had reploaced it with one of these new ones. That is assuming they are considerably stronger and not likely to break under "normal" use. If it also breaks, I'll be recommending that it be further modified to include Pirate's pull-pin - which makes removal and replacement so much easier (at least it does on an unbroken one). |
| Author: | rokraider [ Wed Sep 02, 2009 12:13 am ] |
That is good news Matt, I look forward to fitting one as soon as they are in stock in Europe. |
| Author: | Astro [ Wed Sep 02, 2009 2:25 pm ] |
astro applauds your efforts...i'll take a dozen please... |
| Author: | Cowsgomoo [ Wed Sep 02, 2009 7:53 pm ] |
Great news. I haven't had any problems but I might add some to the spares bag. |
| Author: | saipedaddlefisher [ Fri Sep 04, 2009 4:59 am ] |
Thank you Hobie R&D Department Having broken several of the current black rudder pins early on (and subsequently being less adventurous in using my AI for the past 6 months or so) this now means I can procure a few of the improved grey pins and sail with a lot more confidence and enjoy this marvelous craft even more than I have been doing. Well done guys |
| Author: | ElementAI [ Sat Sep 05, 2009 6:46 am ] |
I still am on my original pin the 2008 Boat came with but have 2 spares. I must not be going at it hard enough or the fact that I have yet to cleat the rudder down. I can encounter sandbars suddenly and it would not kick up. Glad Hobie is always listening to feedback to improve an already great boat. I guess this improvement will help some. Edit: She finally popped her first rudder pin last Sunday in some fast action in some 20mph+ winds! Hiked out on the tramps and soaked to the skin and grinning like a fool. Then suddenly bam and the rudder was dangling by some string. Replacement was easy once I reached shore and settled. Steerage does feel a little looser now... Not sure what's up with that. Glad I had the backup pin. E |
| Author: | Tom Ray [ Tue Sep 08, 2009 7:17 pm ] |
I am still on my original pin, and will hang on to my handful of black spares. With all due respect to the Hobie engineers, I kinda want to see if any of you guinea pigs crack your hulls. |
| Author: | Pirate [ Sat Sep 26, 2009 1:05 am ] |
Sorry guys but my original belief that it is not so much the hardness of the pin material that is the issue but engineering and quality control problems surrounding the gudgeon pin and pintle diameters that is causing the problem in many boats. Like Tom I will await passing of time before I give this 'fix' a thumbs up....Pirate |
| Author: | KayakingBob [ Sat Sep 26, 2009 9:01 am ] |
Welcome back Pirate! It's been quiet around here without you. |
| Author: | Pirate [ Sat Sep 26, 2009 5:22 pm ] |
reconlon wrote: Welcome back Pirate! It's been quiet around here without you. |
| Author: | rockcrawler [ Fri Oct 02, 2009 1:16 pm ] |
mmiller wrote: Note upper pin is new - Gray... lower image is the original black pin. This is not a retrofit issue or a free upgrade. Simply order a new pin using the original part number: 81394001 RUDDER PIN, TWIST N' STOW RDR Our parts department is only stocking the new version. 2010 AIs will come with these new pins. Other models will be using the black pins until the stock runs out. Dealers were informed of the change last week. I recently ordered a spare pin after reading this post. What I received was a black pin. What gives? |
| Author: | KayakingBob [ Sun Oct 04, 2009 8:15 pm ] |
Wrong pin, send it back. The old stock works on all other Hobie's except the AI. |
| Author: | rockcrawler [ Thu Oct 08, 2009 4:27 pm ] |
Took the pin I ordered into the dealer today and they replaced it no problem with the new gray ones they just got in stock. I don't think they knew the pin had been redesigned. |
