| Need help to adjust rudder on AI http://www.hobie.com/au/en/forums/viewtopic.php?f=71&t=31709 |
| Author: | Woodtracker [ Tue Sep 14, 2010 5:14 pm ] |
| Post subject: | Need help to adjust rudder on AI |
Last time I was out the handle was hardly turning the rudder, so I need help on how to tigthen the line it's the left line that is loose . 1) Do I tight it by loossening the bolt on the rudder or 2) is it done from the inside through the rear hatch wich seem to be realy hard to reach. Thanks (excuse my english) Dan |
| Author: | dosjers [ Wed Sep 15, 2010 4:38 am ] |
| Post subject: | Re: Need help to adjust rudder on AI |
Dan, When I adjusted mine I did it at the screw on the rudder. You might want to give a Hobie dealer a call before you mess with it though. |
| Author: | mmiller [ Wed Sep 15, 2010 9:35 am ] |
All line tension is handled at the rudder. We have instructions here: http://www.hobiecat.com/support/articles/archive/?src=http://2010.archive.hobiecat.com/support/tech/Twist-n-Stow_Repair_Manual.html |
| Author: | Woodtracker [ Wed Sep 15, 2010 4:18 pm ] |
Thanks guys for your help I have fix the problem. I guess this is something I will have to put on my check list to make sure I have the right tension on the line. Dan |
