| Attaching AI Cradles to Thule Aero bars. http://www.hobie.com/au/en/forums/viewtopic.php?f=71&t=44784 |
| Author: | Silky6 [ Fri Aug 31, 2012 2:33 pm ] |
| Post subject: | Attaching AI Cradles to Thule Aero bars. |
Hi, Has anyone attached the Hobie trailer cradles to Thule Aero bars using the T slot? If you have what length of screw bolt do you need? If not available then what is the best way to attach? Cheers Silky |
| Author: | NOHUHU [ Fri Aug 31, 2012 5:19 pm ] |
| Post subject: | Re: Attaching AI Cradles to Thule Aero bars. |
Well, I thought about going this route and decided against it. Personally, I would use a carriage bolt through a set of square bars for this application, or add clamp-on Thule saddles (which I did). The thin, slide-in T-bolts are made for lighter equipment mounts, like bikes or snowboards. The longer you make these, the less you will be able to trust them. I get the impression that Rhino Rack's channel system is much more robust and maybe up to the job. Our Aussie friends may be able to comment on this. |
