| Rudder Line needed for Newer Island http://www.hobie.com/au/en/forums/viewtopic.php?f=71&t=49677 |
| Author: | Yakaholic [ Sun Oct 27, 2013 3:30 pm ] |
| Post subject: | Rudder Line needed for Newer Island |
Have a 2010 hull with the newer bigger rudder (not twist 'n stow) and broke the "down" rudder line. It snapped outside the hull a few inches past the rudder pin, almost to where it connects to the rudder. Looks like with about a 3foot length of line I can fix this. What weight kevlar line is this rated Part number for the line? I'd like to buy enough line to replace left/right/up/down in necessary. Have other friends with Islands that I know will want to carry some line. So I'd like to get a bulk of it like 25'? Please point me in the right direction, must go sailing again soon. Also what size are the 2 Stainless Steel split pins set into to rudder to which the up & down lines attach to. Might need them too so part number or size? TIA Edit: Saw some 1/8" diameter 1050# test spectra braided spear gun reel line which also came in 550# test and 1.9 mm wondering if that would work. http://www.amazon.com/Spectra%C2%AE-Bra ... d_sim_sg_3 |
| Author: | Chekika [ Sun Oct 27, 2013 5:47 pm ] |
| Post subject: | Re: Rudder Line needed for Newer Island |
Austin Canoe & Kayak has Hobie accessories. Here is a link to rudder line by the foot: http://www.austinkayak.com/products/632/Hobie-Mirage-Replacement-Rudder-Line.html They have other rudder line options. Keith |
| Author: | Yakaholic [ Sun Oct 27, 2013 7:01 pm ] |
Thanks Keith I think what confused me is all the different sizes of line used. My old Hobie Sport uses a small line. An older Island w/ twist 'n stow has a little bigger line. Finally the newer Island with the big TI style rudder has a massive rudder line. I obviously want the heaviest one but everything seems replaced with one type of spectra line part #81023001. Backyard Boats lists it as "Line Control 700lb. gray @ $.30 a foot - same price as Austin Kayak. My line that broke was white but this part number looks to be what I need. I read somewhere that Hobie used a wax coated spectra line that caused problems and was replaced a few years ago. Thanks again. |
| Author: | Bcastile [ Mon Oct 28, 2013 4:41 pm ] |
The yellow line we use on the Islands is 1000 pound spectra, part number 81051001. |
| Author: | Yakaholic [ Mon Oct 28, 2013 6:35 pm ] |
Bcastile wrote: The yellow line we use on the Islands is 1000 pound spectra, part number 81051001. Hey thanks. I'd rather have the 1,000# spectra than the 750#. I kept looking at a new up/down line kit for Hobie which was a few years old and for the AI. It is definitely gray and was made for the twist n' stow. I compare that to the broken line on the newer AI with the big blade TI style rudder and the TI line is bigger. Backyard Boats calls it 81051001 - LINE-CONTROL 1,000 lb, BEIGE @ $.32 / foot Austin Kayak doesn't list it. At only 2 cents more a foot getting the heavier correct line is a no brainer. Thank you for chasing down the part number. It is not pictured anywhere in the accessories brochure. BTW out of 5 Hobies I own and including those I sold I have never broken a rudder line. The spectra used is just that good. My TI style line broke because I had the rudder cleated down and the rudder stuck something quite hard while moving at a good speed. I had enough tail left to splice the line back to keep using the rudder. |
| Author: | jb7 [ Mon Aug 29, 2016 8:59 am ] |
I need to replace rudder lines for my AI and also for friend`s AI.....thanks for the info on the spectra line. Is this same 1000# line also suitable for replacing steering lines on the AI ? Thanks.....John |
| Author: | mjfxd [ Mon Aug 29, 2016 10:18 am ] |
ack does have it http://www.austinkayak.com/products/136 ... der%20line albeit .34/ft |
