| Just starting out http://www.hobie.com/au/en/forums/viewtopic.php?f=71&t=55144 |
| Author: | Sunchaser_SWMI [ Sat Jun 27, 2015 2:59 pm ] |
| Post subject: | Just starting out |
Hi all, I've been monitoring the forum for awhile leading up to my purchase, and now that I have my boat - I thought I would register and ask for a few tips. I bought a used 2014 Tandem Island that I will mostly be sailing solo (but want the flexibility of having additional seating in case I have company) My main body of water will be Lake Michigan, sailing from Southwest Michigan (New Buffalo, St. Joseph, South Haven). I am currently taking sailing lessons, but am fairly green. I should also mention that I have a trailer for he boat. One more thing i will note - i am a large fellow. About 280 pounds. A few questions, in no particular order: *What are the best web sites/apps to see the water conditions and wind speed? The water was pretty choppy on my maiden voyage today. Didn't see any other boats out, which should have given me a clue it was probably a bad idea to be out. Wondering the best way to check that before getting down to the water. *Thoughts on boat launches vs. driving to the beach and dragging the boat to the water? I thought I'd be going mainly to the beach, but after trying to haul the boat around today, I am re-thinking this strategy. Do the plug-in wheels make a huge difference, or should I just launch from the boat launch? If the plug-in wheels are a good investment, should I just get one - or the pair? *What is the maximum wind speed that it is safe for a fairly new sailor to have full sail out? At which point should I be furling? *Is it best to sail from the front or back seat? On the forums, in videos, etc... I see a lot of folks solo sailing the TI from the back seat, but this would seem to make it harder to control the furling line and the centerboard controls. I think that is it for now. I'm sure I will have more questions later, but those are the most pressing for now. Thanks in advance! |
| Author: | skymax [ Sun Jun 28, 2015 7:07 pm ] |
| Post subject: | Re: Just starting out |
One plugin wheel should be fine. |
| Author: | tonystott [ Sun Jun 28, 2015 8:11 pm ] |
Sunchaser_SWMI wrote: Hi all,
I've been monitoring the forum for awhile leading up to my purchase, and now that I have my boat - I thought I would register and ask for a few tips. I bought a used 2014 Tandem Island that I will mostly be sailing solo (but want the flexibility of having additional seating in case I have company) My main body of water will be Lake Michigan, sailing from Southwest Michigan (New Buffalo, St. Joseph, South Haven). I am currently taking sailing lessons, but am fairly green. I should also mention that I have a trailer for he boat. One more thing i will note - i am a large fellow. About 280 pounds. A few questions, in no particular order: Firstly, you are a lightweight compared to me... *What are the best web sites/apps to see the water conditions and wind speed? The water was pretty choppy on my maiden voyage today. Didn't see any other boats out, which should have given me a clue it was probably a bad idea to be out. Wondering the best way to check that before getting down to the water. Can't help you there, as my weather reference sites are different down under *Thoughts on boat launches vs. driving to the beach and dragging the boat to the water? I thought I'd be going mainly to the beach, but after trying to haul the boat around today, I am re-thinking this strategy. Do the plug-in wheels make a huge difference, or should I just launch from the boat launch? If the plug-in wheels are a good investment, should I just get one - or the pair? I just launch my TI from the trailer at local ramps, or even straight into the water if the shoreline won't find me getting bogged. *What is the maximum wind speed that it is safe for a fairly new sailor to have full sail out? At which point should I be furling? This is easy really... you should furl the sail when the ama is tending to lie level with the water. As you are starting out, you could probably furl a bit earlier. *Is it best to sail from the front or back seat? On the forums, in videos, etc... I see a lot of folks solo sailing the TI from the back seat, but this would seem to make it harder to control the furling line and the centerboard controls. As a bigger bloke than you, I sail from the front seat, which puts my heft approximately amidships. If I sat at the back, I don't want to think how high the bow would point! I think that is it for now. I'm sure I will have more questions later, but those are the most pressing for now. Thanks in advance! |
| Author: | ChangeMan [ Sun Jun 28, 2015 8:38 pm ] |
Hi Sunchaser. I'm sure a local can best answer the first questions. What is the maximum wind speed? - This will vary per individual. You should note the forecast and work out the highest wind you are comfortable with. Because you can furl the sail many of us will go out in reasonably high winds. You will know that the wind is too strong when you start burying the windward ama completely. Sail from front or back seat? - The back seat is drier and keeps the nose from going under too much when in the front seat. Some believe there is a risk of cartwheeling from the front seat. As we don't raise the dagger board often, that's not so much a problem. I found cleating the furling sheet a problem on one outing. I attached a light cord to an O ring, fed the furling sheet through the ring. Took the cord under the Aka, around and over then back to the rear seat. This allowed me to pull down the furling sheet to make sure it went into the cleat. Maybe I shouldn't have been sailing in those winds as it was an adrenalin experience when the sail fully unfurled in high winds. Overall, just be patient, take your time, don't have too much sail out and you will be guaranteed lots of fun. PS - just proves there is no right or wrong as Tony has also posted that he uses the front seat since me drafting a reply to tell you to use the rear seat. |
| Author: | Sunchaser_SWMI [ Mon Jun 29, 2015 4:41 am ] |
Thanks for all the replies - these are some good tips! I took the boat out yesterday from the boat launch, and that was much easier than trying to lug the boat down to the beach. I sailed from the back - but next time I'll try sailing from the front to see how different it is. Thanks again! |
| Author: | SeaWorthy [ Mon Jun 29, 2015 12:37 pm ] |
as for apps to see water currents and wind speeds try out the Navionics iPhone app, it has a free one week trial. I tried it out that way and then upgraded it for a year $9.99 Sam |
| Author: | AIChris [ Mon Jun 29, 2015 3:05 pm ] |
I like winds in the 8 to 20 knot range. If they are lower, around here they also tend to be variable and not much fun to sail in. Slightly higher is ok, and it's doable, but it starts to become less fun and more worry, at least for me. 30 knots and I would stay home and wait for it to quiet down. I like Windfinder and Weather Underground apps/web sites for wind and weather information. Magic Seaweed is good for tides and surf, if that is helpful in unsalted and shark-free Lake Michigan. -Chris |
| Author: | Yakass [ Tue Jun 30, 2015 11:50 pm ] |
Regarding wind speed... there's more to it than just the speed of the wind. Water conditions will dictate on-water performance somewhat in stronger winds. There is no magic number. |
| Author: | TI_Tom [ Wed Jul 01, 2015 1:00 pm ] |
I like winds in the 10-20 knot range. I tried sailing from the rear seat and found the furling line setup cumbersome and the dagger board was almost impossible for me to reach. I feel more comfortable in the front seat. For wind forecasts I use the windfinder app. I agree with changeman about taking your time and getting used to having more and more sail out. |
| Author: | WickedGood [ Wed Jul 29, 2015 11:26 am ] |
Sunchaser_SWMI wrote: Hi all, I've been monitoring the forum for awhile leading up to my purchase, and now that I have my boat - I thought I would register and ask for a few tips. I bought a used 2014 Tandem Island that I will mostly be sailing solo (but want the flexibility of having additional seating in case I have company) My main body of water will be Lake Michigan, sailing from Southwest Michigan (New Buffalo, St. Joseph, South Haven). I am currently taking sailing lessons, but am fairly green. I should also mention that I have a trailer for he boat. One more thing i will note - i am a large fellow. About 280 pounds. A few questions, in no particular order: *What are the best web sites/apps to see the water conditions and wind speed? The water was pretty choppy on my maiden voyage today. Didn't see any other boats out, which should have given me a clue it was probably a bad idea to be out. Wondering the best way to check that before getting down to the water. I like to use the National Weather Service website. http://marine.weather.gov/MapClick.php?lon=-86.76175&lat=41.84286#.VbkVJ_lc6d4 If you go to the page you will see a small map on the right hand side about half way down the page. You can click on the map and get a new "point forecast" for wherever you will be sailing. Click on the land and get a land forecast, click on the water and get a marine forecast. These forecasts are from the guys that issue the "Small Craft Advisories". *Thoughts on boat launches vs. driving to the beach and dragging the boat to the water? I thought I'd be going mainly to the beach, but after trying to haul the boat around today, I am re-thinking this strategy. Do the plug-in wheels make a huge difference, or should I just launch from the boat launch? If the plug-in wheels are a good investment, should I just get one - or the pair? We have used both at different times. For boat ramps its great to have the trailer. For beaches its great to have one pair of the plug-in wheels. (Make sure to get the TI cradle that fits the plug-in wheels as it is designed to spread the load.) The wheels are only suitable for the kayak, not when it is assembled with amas, etc. *What is the maximum wind speed that it is safe for a fairly new sailor to have full sail out? At which point should I be furling? Like was already said by other members, its not just about wind speed. There are many factors such as point of sail, sea state, vessel loading (especially whether someone is hiked out on a trampoline), etc. that all come into play when deciding whether to reef the sail or not. But its always better to reef too early than too late! After some time on the water you will learn how to better judge the overall conditions and make the call on reefing. *Is it best to sail from the front or back seat? On the forums, in videos, etc... I see a lot of folks solo sailing the TI from the back seat, but this would seem to make it harder to control the furling line and the centerboard controls. Can't help on this one, as we are always both in the boat. Kris in the front (handling furling) and Chris in the rear (handling everything else). I think that is it for now. I'm sure I will have more questions later, but those are the most pressing for now. Thanks in advance! The TI is a great beginner sailboat and is super fun! My (Chris) answers to your questions are above in red. |
| Author: | cooldudecaptain [ Wed Jul 29, 2015 6:40 pm ] |
re: beach wheels If you sail solo, just remember you have to either lift the TI high enough to insert the wheels or roll the TI on its side.......unless you can install the wheels as you slide the TI off the trailer and then remove and/or install the wheels while standing in shallow water. Weather and wind will determine that option. I prefer the Hobie Dolly for my 2014 TI. Just an opinion. bill |
| Author: | scc [ Wed Jul 29, 2015 7:17 pm ] |
ChangeMan wrote: You will know that the wind is too strong when you start burying the windward ama completely. As not to confuse the OP, I think you meant leeward ama. I'd only add that the Garmin BlueChart mobile app with USA map upgrade (around $40) and the weather upgrade (around $5) have been well worth the price. I can see multiple weather parameters including wind speed, direction, wave state, dew points, temps, GRIB forecasts for a week out, etc. It interfaces with ActiveCaptain and allows route planning (not navigation though). Very impressed with it. |
