| PFD for Islands (TI and AI) http://www.hobie.com/au/en/forums/viewtopic.php?f=71&t=56711 |
Page 1 of 2 |
| Author: | PeteCress [ Tue Jan 19, 2016 11:29 am ] |
| Post subject: | Re: PFD for Islands (TI and AI) |
hjdca wrote: ...my newest PFD ... I really like this new setup. It gives me a lot of freedom and I have everything I need... Have you tried it out in deep water, manually inflated ?After trying that with mine (different brand...) and finding it more like a ring around my neck than a PFD, I wound up adding crotch straps. |
| Author: | vetgam [ Tue Jan 19, 2016 12:44 pm ] |
Pete where did you find the crotch straps. Are the universal? |
| Author: | PeteCress [ Tue Jan 19, 2016 1:21 pm ] |
vetgam wrote: Pete where did you find the crotch straps. Are the universal? Sewing machine, 1.5" webbing, snap-connectors + D-rings...... and a few hours work...http://www.amazon.com/gp/product/B008CD ... ge_o06_s00 http://www.ebay.com/itm/231227173079?_t ... EBIDX%3AIT https://picasaweb.google.com/1081497986 ... 6120472834 All probably technically illegal.... |
| Author: | tonystott [ Tue Jan 19, 2016 3:55 pm ] |
PeteCress wrote: vetgam wrote: Pete where did you find the crotch straps. Are the universal? Sewing machine, 1.5" webbing, snap-connectors + D-rings...... and a few hours work...http://www.amazon.com/gp/product/B008CD ... ge_o06_s00 http://www.ebay.com/itm/231227173079?_t ... EBIDX%3AIT https://picasaweb.google.com/1081497986 ... 6120472834 All probably technically illegal.... I seriously doubt that Pete, in fact, I would like to see PFDs WITHOUT crotch straps declared technically illegal! |
| Author: | PeteCress [ Tue Jan 19, 2016 5:02 pm ] |
tonystott wrote: I seriously doubt that Pete, in fact, I would like to see PFDs WITHOUT crotch straps declared technically illegal! I was thinking in terms of modifying a PFD rendering it technically no longer in compliance with it's rating.Seems logical - almost manditory... you have a bunch of specs, user fools around with the device...now it's out of spec. I'm with you thinking negative thoughts about PFDs without crotch straps. I put them on my solid/foam PFD too after finding out that it would slip up and over my head just like *that* if I raised my arms beyond a certain point in deep water. |
| Author: | tonystott [ Wed Jan 20, 2016 5:07 am ] |
The overwhelming bonus of fitting crotch straps is that you no longer need to have the PFD cinched up tight to stop it riding up in the water. So you get a huge comfort advantage when you are NOT in the water, ie the vast majority of time. |
| Author: | hawk232 [ Wed Jan 20, 2016 6:34 pm ] |
I am also sorry that I have helped further the sidetracking of this thread. Your vest looks very nicely outfitted, probably the most thought and effort that you have ever put into stuff that you hope to never use right?!?!?! |
| Author: | hjdca [ Sat Jan 23, 2016 12:09 pm ] |
hawk232 wrote: I am also sorry that I have helped further the sidetracking of this thread. Your vest looks very nicely outfitted, probably the most thought and effort that you have ever put into stuff that you hope to never use right?!?!?! lol, I actually like yours much better ! the shape and design looks awesome. |
| Author: | PeteCress [ Sat Jan 23, 2016 12:48 pm ] |
hawk232 wrote: Are those zippers running around the edge of the PFD ?
| Author: | hawk232 [ Sat Jan 23, 2016 5:34 pm ] |
yes. under the flap is an "open" area of zipper. when the vest inflates is splits the zipper and comes out. after deflation you roll the vest up, stuff it back in and zip it up. |
| Author: | PeteCress [ Sun Jan 24, 2016 6:36 am ] |
hawk232 wrote: yes. under the flap is an "open" area of zipper. when the vest inflates is splits the zipper and comes out. after deflation you roll the vest up, stuff it back in and zip it up. And for manual inflation, you just un-zip it ? Or does it not do manual ?
| Author: | hawk232 [ Sun Jan 24, 2016 6:48 am ] |
manual as in pull a cord or manual as in use your mouth? you can not blow it up manually as purchased but they sell a kit to convert it. there is a yellow handle that is tucked in real neat just under the black flap that says spinlock (just to the right of the knot on my hat line). give er a yank and its inflated. |
| Author: | PeteCress [ Sun Jan 24, 2016 6:59 am ] |
hawk232 wrote: manual as in pull a cord or manual as in use your mouth? you can not blow it up manually as purchased but they sell a kit to convert it. As in "Use your mouth".In the pix, it looks like you are not using the crotch strap. My recommendation would be to get the manual kit, inflate it while you are in deep water, and then decide whether you want to use the crotch strap or not...... In the case of mine, it was like having a a ring around my neck instead of a PFD until I added a crotch strap..... Also, as another member observed, a crotch strap allows you to wear the PFD looser/more comfortably and still have it function as intended in the water. |
