| 8" YakAttack Rail w/Backing Plate Behind Centerboard Lever ? http://www.hobie.com/au/en/forums/viewtopic.php?f=71&t=57569 |
| Author: | PeteCress [ Fri May 06, 2016 4:56 pm ] |
| Post subject: | 8" YakAttack Rail w/Backing Plate Behind Centerboard Lever ? |
Has anybody mounted an 8" YakAttack rail w/backing plate behind the centerboard lever? viz: https://picasaweb.google.com/1081497986 ... 1885578386 Seems like the backing plate *should* fit... but I can't get my fingers up behind the drinking cup well to make sure there is enough flat space inside.... and I am reluctant to drill holes before knowing for sure. |
| Author: | jfrancis99 [ Sat May 07, 2016 4:08 am ] |
| Post subject: | Re: 8" YakAttack Rail w/Backing Plate Behind Centerboard Lev |
I have a 4" rail that is 1.5" back from the centerboard lever that works fine. I started it at 1.5" back due to ease of putting the screws on. You can always tape the backing plate to the bottom and then try to work a camera under there with video on to see how much room you have. Not a lot of room to work in, you may need a small child's help getting the bolts started. |
| Author: | PeteCress [ Sat May 07, 2016 4:53 am ] |
jfrancis99 wrote: Not a lot of room to work in, you may need a small child's help getting the bolts started. I bought a couple of what YakAttack callse "Rigging Bullets" and would consider them a good deal even at twice the price: http://www.yakattack.us/RB1420_p/rb1420.htm
| Author: | PeteCress [ Sat May 07, 2016 12:20 pm ] |
PeteCress wrote: Seems like the backing plate *should* fit... For the benefit of anybody else on this little journey..... 8": Nope. I went ahead - but, expecting trouble, only drilled the two middle holes and put the bullets in them. Sure enough, it was jamming on the aft end - apparently on the curvature of the hull there. Maybe 1/4".... So I cut off an inch from both backing plate and track so now I had a 7" track/backing plate instead of 8". 7" finally fit - but it was till something of a jam fit.....I kept tightening up the screws a half-turn at a time for maybe 30 minutes as the backing plate seemed to settle in to the poly. Not sure where/how, but I suspect that mounting it in the center (left-right-wise) was the problem. Probably should have moved it 1/8" or so inboard of center. Would have been totally impossible without the bullets.... but even with the bullets, a child's small hands might have made a diff. |
