| Mast camera mount for AI http://www.hobie.com/au/en/forums/viewtopic.php?f=71&t=58118 |
| Author: | Scrumpy [ Mon Jun 27, 2016 2:45 am ] |
| Post subject: | Mast camera mount for AI |
I've seen a few photos and some video footage taken from the masthead of Hobie Island kayaks and I love the view that it provides. However, I could find no information on the web regarding the actual design of a mount so I decided to go ahead and create my own. Here it is below. ![]() First thing to state is that if you fit the Genuine Hobie Spinnaker kit to your Adventure Island this mount won't fit!, sorry. My biggest concern was attaching a mount o the mast itself, it needed to be none damaging and preferably without any modifications to the mast itself. These masts are not cheap!, damaging one or weakening one, quite simply wasn't an option. At the top of the AI mast is a plastic insert that is used to locate the sail securing strap (photo below) ![]() I noticed that with the strap fitted through this plastic insert that there was still approximately 3mm of clearance between the strap and the plastic lugs. I decided to try to utilise this gap to locate and secure a camera mount to the mast. I located a piece of aluminium of the correct thickness and cut off a long strip of the correct width, filing it down to a 'sliding fit'. My first attempt (Mk1) saw me fold the aluminium strip over on itself, allowing it to slide through the plastic mast mount before securing it with a nut and bolt as shown below. ![]() Despite being a close fit in the mount, the bracket moved more than I liked so I added a heavy ty-wrap to lock it into position. ![]() This worked extremely well and I thought I had a good working solution. However, the more I played with it I noticed that if it was subjected to a decent knock it would vibrate for 1-3 seconds which I deemed unacceptable. The basically made the Mk1 scrap metal, so I moved onto designing a strengthened Mk2 version. The horizontal section that supported the camera really needed to be solid with zero flex. The only way that I could effectively achieve this was to add an upright section along this horizontal length, thus preventing any noticeable flexing. I also took this opportunity to modify the upright section, extending it to permit the fitment of a wind indicator. I purchased a Little Hawk Mk1 for this purpose. This is a very simple indicator that attaches to a vertical surface using two small self tapping screws. Below are a couple of photos of the welded and painted bracket. Being aluminium it's very lightweight yet its design makes it very rigid. ![]() ![]() It slides into the top plastic mount on the AI masthead and it secured into position with a heavy duty ty-wrap as per the Mk1. It really is as simple as that and it's a very solid fit!, simple but effective as they say. ![]() Note that a GoPro mount is fitted, I've used a nut and bolt as I envisage that the main bracket will remain fitted at all times, though you could use a 'wing nut' for quick removal of this mount if preferred. ![]() ![]() The Hawk wind indicator mount can be seen fitted in the above photo. This is a permanent fit. ![]() As mentioned, the bracket assembly is secured to the mast with a ty-wrap. Removal and fitment takes seconds! The Hawk wind indicator pushes in when needed and the GoPro is also attached on as as-required basis. The whole mount, wind indicator and GoPro can be assembled and fitted in a minute, literally. Below is the Hawk wind indicator fitted into its bracket. ![]() ![]() Below is the GoPro secured to its mount. ![]() ![]() Below is the fitted 'Mk2' mount complete with camera and wind indicator. ![]() ![]() I'm going to be testing it very shortly and I'll post up some of the results - fingers crossed! |
| Author: | nap [ Mon Jun 27, 2016 3:20 pm ] |
| Post subject: | Re: Mast camera mount for AI |
Nice. Thanks for sharing. Yes please share your first video. |
| Author: | TI_Tom [ Mon Jun 27, 2016 7:08 pm ] |
Very cool! Now to adapt one to work with the hobie mast topper. Sent from my SPH-L720T using Tapatalk |
| Author: | tonystott [ Mon Jun 27, 2016 11:16 pm ] |
TI_Tom wrote: Very cool! Now to adapt one to work with the hobie mast topper. Sent from my SPH-L720T using Tapatalk I reckon it would be doable Tom, but I suspect you would need a very light camera as well as counterweights, to avoid overpowering the delrin ballrace. There is room front and back to insert (say) carbon arrow shafts terminating in a HPDE block just big enough to take the mounting for the camera. A small weight at the other end (the arrow shafts sticking through so equal amounts are exposed on each side) to avoid putting lopsided loads on the ballrace. Unlike nap's solution, which would swivel directly with the sail, this one would rotate with the mast topper. Unfortunately, from my observations, that can be quite erratic jerks through a small angle. The ideal outcome is to have the camera free to rotate the mast in a large arc, as per Matt Coburn's spectacular efforts. I have no idea how that could be incorporated with the mast topper. https://www.youtube.com/watch?v=VqdQL90sDVo |
| Author: | scc [ Mon Jul 04, 2016 8:37 am ] |
tonystott wrote: The ideal outcome is to have the camera free to rotate the mast in a large arc, as per Matt Coburn's spectacular efforts. I have no idea how that could be incorporated with the mast topper. https://www.youtube.com/watch?v=VqdQL90sDVo tonystott, Love this video! Do you know if Matt Coburn has detailed his mount on the forum or elsewhere? |
| Author: | tonystott [ Mon Jul 04, 2016 11:00 am ] |
scc wrote: tonystott wrote: The ideal outcome is to have the camera free to rotate the mast in a large arc, as per Matt Coburn's spectacular efforts. I have no idea how that could be incorporated with the mast topper. https://www.youtube.com/watch?v=VqdQL90sDVo tonystott, Love this video! Do you know if Matt Coburn has detailed his mount on the forum or elsewhere? Not that I am aware of.. I recall him mentioning that it is free to swing around the mast, presumably dictated by the direction the mast is leaning. It seems to move so gracefully, he really has hit the jackpot there. |
| Author: | stringy [ Mon Jul 04, 2016 4:50 pm ] |
Scrumpy, nice work on that mast mount and great documentation. I was very interested in a rotating mast mount like Matt Coburns when he first posted his surfing video in this forum here: viewtopic.php?f=32&t=53004&p=243818#p243818 He didn't provide details on his mast mount but if you look closely, when the boat is righted, a shadow is cast on the sail that gives a bit of an idea. I researched rotating mounts and I believe his mount is very similar to this one: http://www.diygopro.com/diy-gopro-swive ... -improved/ I ended up making this from the ideas found in the above link ![]() I upgraded my GoPro last year to the Silver model so I could get the wifi benefits that allow remote control by a smartphone app. Truth is I've only used it once. I found the video to be boring just sailing around and the constant rotating gets annoying. Also you don't get a long battery life on wifi and changing batteries is a real pain! Matt's video works so well because of the exciting subject matter and editing. Rotating footage is best viewed in slomo. It does allow for interesting still shots though:
