| Twist-and-Seal Hatch Installation: Machine screws instead ? http://www.hobie.com/au/en/forums/viewtopic.php?f=71&t=62037 |
| Author: | PeteCress [ Fri Jan 12, 2018 2:14 pm ] |
| Post subject: | Twist-and-Seal Hatch Installation: Machine screws instead ? |
Reading https://www.austinkayak.com/assets/pdf/ ... ctions.pdf, I come away thinking that the "Backing Ring" just functions as nuts/washers for the self-tapping screws. That being the case, I am tempted to dispense with the 3/16" holes and backing plate and simply use machine screws through just-large-enough holes with washers and nylock nuts on the inside of the hull. Can anybody point out the error of my ways? Full Disclosure: this hatch is going into the fiberglass cockpit of an OC-1 instead of an AI: https://photos.google.com/album/AF1QipM ... D1ETIZtgKq https://photos.google.com/album/AF1QipM ... YCreTOqy6d |
| Author: | KayakingBob [ Fri Jan 12, 2018 7:10 pm ] |
| Post subject: | Re: Twist-and-Seal Hatch Installation: Machine screws instea |
Should work. It could be a bit less as strong without the lower plate to help sandwich the hatch hole but calking might make up some it. |
| Author: | Buckaroo [ Sun Jan 14, 2018 5:15 am ] |
I always use anti seize compound on stainless fasteners going into stainless nuts or tapped holes because stainless has a tendency to seize, especially in blind tapped holes in stainless. Alternatively you could drill clearance holes in the ring and preserve the benefits of using it. - C |
| Author: | WAVERIDER [ Sun Jan 14, 2018 4:17 pm ] |
I guess the backing ring could be adding added stfifness to the hull to potentially compensate for any weakness created by the hole |
