| Hobie Tandam free updates http://www.hobie.com/au/en/forums/viewtopic.php?f=71&t=62734 |
| Author: | mlaf60 [ Thu May 17, 2018 6:27 am ] |
| Post subject: | Hobie Tandam free updates |
Hello Matt, First post, I've been following for awhile. I have a question. I've started to update the lock bearings on my 2017 TI. The difference between the old and new is not significant. The new kit I received appears to have both styles. The 4 lock bearings I removed from my TI also have both styles. Both type have the ramp described in the instructions. I'm trying to determine what is the old versus new style. I am not sure how to post images. The best way to describe the difference I see. Type 1: has a curved bevel on the surface the latch will contact. Type 2: has a straight cut with small machined cutaway. thank you |
| Author: | mmiller [ Thu May 17, 2018 3:08 pm ] |
| Post subject: | Re: Hobie Tandam free updates |
The new is primarily the spring hook... has a stainless spring and hinged hooks. If you had that already... you don't need the update. |
| Author: | mlaf60 [ Fri May 18, 2018 7:29 am ] |
Thank you Matt for the reply. I couldn't really see a difference in the in Lock Bearings and probably didn't need to change them. I'll be doing the spring hooks this weekend. |
| Author: | mmiller [ Fri May 18, 2018 4:33 pm ] |
The new bearings have a slight ramp for the hook to rest into. |
