| Is a 2010 mirage drive interchangeable with a 2008 ? http://www.hobie.com/au/en/forums/viewtopic.php?f=71&t=67328 |
| Author: | Fly’n C Lion [ Fri Sep 04, 2020 9:39 am ] |
| Post subject: | Is a 2010 mirage drive interchangeable with a 2008 ? |
Hello! I have a friend who wanted to try out my 2008 adventure islander. I hadn’t used my boat in 2 years and found the mirage drive has an issue which needs fixed. So we were able to insert a 2010 drive, but it took some finagling and is a tiny bit tight. Does anyone know if it would damage the mirage drive well of the 2008 if it is used? Thank you, Wanda |
| Author: | mmiller [ Fri Sep 04, 2020 10:59 am ] |
| Post subject: | Re: Is a 2010 mirage drive interchangeable with a 2008 ? |
With the alignment pins removed and possibly a little filing of the faring... this will work in the older boats. |
| Author: | Fly’n C Lion [ Wed Sep 09, 2020 3:52 pm ] |
Thank you! I will have to brush up on the names for the mirage drive parts My chain assembly had been cut and I was un-able to find one on line, so wanted to use our 2010 mirage drive in it’s place. Today I looked again. Hobie and numerous other companies are out of stock with this item. Then I happily found one at Outdoor Play! Thanks Again, Wanda |
