| Tramp strength http://www.hobie.com/au/en/forums/viewtopic.php?f=71&t=68261 |
| Author: | Ian S [ Thu Apr 29, 2021 9:39 am ] |
| Post subject: | Tramp strength |
I've ordered a set of tramps. I note that the weight limit is 200 lbs, is there any way to strengthen this? My weight is about 240, and I'm wondering how I could get over to the Ama, or get in/out from a dock. |
| Author: | atv223 [ Thu Apr 29, 2021 1:24 pm ] |
| Post subject: | Re: Tramp strength |
I think you are fine as is. Watch this video, he mentions weight on the tramps. https://youtu.be/cgLbiCjrywY?t=39 |
| Author: | LarryJ [ Thu Jun 10, 2021 6:22 pm ] |
Ian S wrote: I've ordered a set of tramps. I note that the weight limit is 200 lbs, is there any way to strengthen this? My weight is about 240, and I'm wondering how I could get over to the Ama, or get in/out from a dock. A haka bench if you're concerned. https://www.hobie.com/forums/viewtopic. ... start=1260 |
| Author: | RedKite [ Fri Jun 11, 2021 1:09 am ] |
I'm heavier than you and not had any problems, although I wouldn't recommend to stand in the middle of a tramp like you might on a bigger Tri - better to share your weight with a hand or two on an aka. |
| Author: | USFWOOD [ Fri Jun 11, 2021 7:49 am ] |
Good Morning Lightweight. I am over 270 and sat on them, lied down on them, and ,stepped on them, even at the dock. I too was concerned about the stated weight limit. Mine are fairly new, and I saw one post where the straps/buckles came off on someone and they replaced them with something stronger. I don't feel the material will give way. One thing I have considered was to run webbing straps across the length of the tramp. I am also looking at the spine board HAKA. What is more bothersome to me is that I can sink the ama if I am far out on the tramp. Good luck. |
