| Trailex SUT-250 for a TI? http://www.hobie.com/au/en/forums/viewtopic.php?f=73&t=55969 |
| Author: | CaptainFlint [ Wed Sep 09, 2015 6:03 pm ] |
| Post subject: | Trailex SUT-250 for a TI? |
I know the SUT-350 is a popular trailer. But, I can snag a 250. Think that'll work for a TI? Short distance, under 10 miles. Note that it's the SUT-250-M2 (https://www.trailex.com/SUT-250-M2.cfm). So, I can remove the riser bars, transport it upside down. Also, I think I can store it on this trailer, too, since it'll be upside down (if I use some padding). Thoughts? Thanks! |
| Author: | mmiller [ Thu Sep 10, 2015 12:22 pm ] |
| Post subject: | Re: Trailex SUT-250 for a TI? |
250 lb capacity TI is 198 with all the gear. |
| Author: | CaptainFlint [ Thu Sep 10, 2015 1:20 pm ] |
So, should be OK. I like it because it's avaialable nearby and built. Matt-OK to store the TI on that, upside down? Thanks. |
| Author: | mmiller [ Thu Sep 10, 2015 3:38 pm ] |
Upside down... yes, but why? I would make a platform of plywood wide enough and long enough to get two of the cradles attached and then carry assembled upright. If only for an occasional short move... You could even simply pull up on the plywood platform and tie down. |
| Author: | stringy [ Thu Sep 10, 2015 3:39 pm ] |
mmiller wrote: 250 lb capacity TI is 198 with all the gear. Matt, The real weight specs for a 2015 TI that you previously acknowledged here are 240lbs for a fully rigged boat. Carrying all the bits on the trailer you would be very close to its limit. Whatever framework you added to carry the TI would probably put you over that limit. You would have to carry the drives, paddles, seats etc in the vehicle so the trailer capacity isn't exceeded. I recently weighed my 2010 TI and got a fully rigged weight of about 228 lbs A TI has never weighed 198lb fully rigged. Where does this 198lb figure come from? Why do Hobie persist in publishing incorrect weight specs? The AI figures are way off as well. |
| Author: | Media1der [ Thu Sep 10, 2015 4:10 pm ] |
I don't know if you are looking at a used trailer ... but at the list price, I'd keep looking. For under $1500, our local trailer dealer (Wilderness Adventure Trailers, Holland Michigan) custom built out their Kayak Kaboose trailer WITH the TI cradles, ready to go. We just back down the ramp and slide the TI right into the water (amas folded) then set up and go ... coming back we fold in the amas, and the TI pushes right back onto the cradles, with the bow supported by the spare. We cover and store until the next adventure. Easy Peasy. What I suspected has been proven out -- the Pain In the Ass (PIA) factor is inversely proportional to the odds that you will get out on your boat on a moment's notice. When you're chasing a warm breeze, ease of launching matters. A lot. http://www.wildernessadventuretrailer.com/product/kayak-kaboose/ If you're interested, click through the link for the number; give Skip a call and have him price it out for you. Good guy. (I get no kickbacks; just rewarding a good local company with a referral.) ~ Chris |
| Author: | mmiller [ Fri Sep 11, 2015 10:22 am ] |
stringy wrote: A TI has never weighed 198lb fully rigged. Where does this 198lb figure come from? Why do Hobie persist in publishing incorrect weight specs? The AI figures are way off as well. I simply reference our own website (can't trust my memory!). I was pretty sure they fixed all that last year, but maybe driven by 2016 updates and wrong data got in again? I'll point that out to marketing. |
| Author: | mmiller [ Fri Sep 11, 2015 11:20 am ] |
Corrected on the site, Yes 240 lbs. So, marginal, but for short hauls as noted... the SUT250 should work. Especially if your carry drives and seats in the car. |
| Author: | stringy [ Fri Sep 11, 2015 2:23 pm ] |
mmiller wrote: Corrected on the site, Yes 240 lbs. Thanks Matt. Now while you've got the ear of those marketing guys can you get them to fix the AI specs? Should be 185lbs fully rigged. Then I can go back to getting a good nights sleep! |
| Author: | Chekika [ Fri Sep 11, 2015 2:30 pm ] |
mmiller wrote: Corrected on the site, Yes 240 lbs. So, marginal, but for short hauls as noted... the SUT250 should work. Especially if your carry drives and seats in the car. It has taken a long time, years, to get the correct weight for the Hobie Tandem Island on the Hobie site (assuming it is now correct.) The Hobie site still shows 142# as the weight for the 2015 AI. The correct weight for the 2015 is 185# as you noted on this forum. That misrepresentation on your web site, which is clearly deliberate and has gone on for more than a year, could seriously mislead some people. It is just not right. Keith |
| Author: | mmiller [ Fri Sep 11, 2015 3:27 pm ] |
Marketing will look at all of them next week again. |
