It is currently Thu Apr 25, 2024 8:27 am
PostPosted: Sun Jul 25, 2021 6:32 pm
If you have an older TI where the mast plate is welded to the forward side of the cross bar be sure to check that weld regularly, especially after a strong wind.
This led to the whole thing being twisted so I couldn't easily get the mast out.
Loosening the screws on the plate holding the ball bearings did the job.
FWIW, this was obviously a weak point that was identified, as later models have that plate extend through the cross bar and welded on the aft side.
PostPosted: Mon Jul 26, 2021 3:42 pm
https://www.hobie.com/forums/viewtopic.php?f=21&t=12574
PostPosted: Mon Jul 26, 2021 3:46 pm
I opened your image in a new tab and copied that URL... That worked.
