Hobie Forums http://www.hobie.com/au/en/forums/ |
Sheared bolt in the mast base, Need help. http://www.hobie.com/au/en/forums/viewtopic.php?f=75&t=64725 |
Page 2 of 2 |
Author: | Kainoa [ Mon Sep 14, 2020 11:00 am ] |
Post subject: | Re: Sheared bolt in the mast base, Need help. |
Thanks to a warning by a recent WaterTribe post I pulled and inspected my bolt the other day. All was well so I greased and re-installed it. I did notice that some nuts on the turnbuckles had worked loose so I tightened those. I'll be "checking under the hood" more frequently now in order to avoid bolt failure to the extent I can. |
Author: | Sardinian Islander [ Wed Sep 16, 2020 11:28 am ] |
How did u spend 12000 euros for the tandem Island? |
Author: | Yopcitron [ Thu Sep 17, 2020 4:56 am ] |
How ....simple .. :- ) Hobie TI : 8639 euros Trempolines : 528 euros cart : 369 euros Trailer : 1590 euros Smalls parts : .... So 12 000 / 13 000 dollars For the same price it is possible to have a "true serious" boat ! So for this price i thought i will have an indestructible nice small boat or if it's not the case .....an irreproachable after sales service ! not a response like ..."you screew to be broken ...it is normal ...just change it" ! ..Sorry I'm still a little pissed off, haven't been able to use my boat for a year now. |
Author: | solanra [ Sun Aug 28, 2022 9:05 pm ] |
The mast step bolt just sheared off for a second time yesterday in my Hobie TI 2015. This time in only moderate wind with no spinnaker up. Last time I managed, with much difficulty, to cut a slit in the top of the sheared off bolt with a hacksaw and remove the old one with a scewdriver. This time it is deeper down. I share the frustration of others in this thread. It seems obvious that this is a design flaw that Hobie should rectify.... what to do now? The repair will be long and difficult but why bother if it's just going to break again.... |
Author: | powersjr2 [ Tue Sep 06, 2022 7:43 pm ] |
Agree, The Hobie 2015 and older have a 1/4 inch bolt vs. the newer TIs with the 3/16" bolt. I have popped this bolt before.... not fun. If you routinely sail in higher winds / rough water conditions / off shore / coastal conditions.... my recommendation....move up to a newer TI..... This is the path I have chosen. If sailing on small lakes in light winds - you should have no problems....just keep an eye on it and swap out a new bolt every few years. Avoid the spinnaker also....unless you have a newer TI. |
Page 2 of 2 | All times are UTC - 8 hours [ DST ] |
