| Steering line lubrication http://www.hobie.com/au/en/forums/viewtopic.php?f=75&t=37138 |
| Author: | JetJester [ Sat Jul 30, 2011 10:31 am ] |
| Post subject: | Steering line lubrication |
I've recently returned from a trip to Lake Tahoe. On sailing day two I noticed that I could only turn one way. Having reached the shore I noticed a lot of slack in the rudder control line on the one side so adjusted it accordingly. That evening when the lines had dried out I noticed that the steering had gone really tight. Should I be using some kind of lubricant on the lines? Thanks JJ. |
| Author: | mmiller [ Mon Aug 08, 2011 3:53 pm ] |
| Post subject: | Re: Steering line lubrication |
Extreme heating / cooling can expand or contract the kayak which makes lines get loose or tighter. Not typically an issue, but hot days and very cold nights or water could do it I suppose. Make the lines were a bit tight and got very tight as the boat heated? No lubrication is required with the newer lines (spectra). It is polyethylene and very slippery. |
