| 2015 TI Mast rotate bearing material and diameter? http://www.hobie.com/au/en/forums/viewtopic.php?f=75&t=65115 |
| Author: | UKTI [ Tue Jul 09, 2019 5:51 am ] |
| Post subject: | 2015 TI Mast rotate bearing material and diameter? |
Have just returned from a great offshore trip around The Lizard and Lands End. TI was great and I camped onboard under an awning. Now have noticed that the mast bearings are still there, but most are in the mast well.... Suspect I will have to replace the bearings and the top and bottom keeper plates. I would like to carry a spare set of bearings. Looks like they are Delryn, and the size is either 10mm, or, 3/8". Can anyone please confirm this? Many Thanks |
| Author: | mmiller [ Tue Jul 23, 2019 10:12 am ] |
| Post subject: | Re: 2015 TI Mast rotate bearing material and diameter? |
90610111 DELRIN BALL 3/8 DIA - FURLERS 24 required 90610112 DELRIN BALL 3/8 DIA (PKG OF 12) |
| Author: | tonystott [ Tue Jul 23, 2019 11:18 am ] |
While you have it apart to replace the bearings, it might be opportune to sand the mating plate faces with a rigid surface to eliminate any high-spots, thus reducing the possibility for future escape of delrin bslls |
| Author: | UKTI [ Wed Jul 24, 2019 2:46 am ] |
Many thanks to you both! |
