| Threading of circular hatch mount screws (Tandem Islander) http://www.hobie.com/au/en/forums/viewtopic.php?f=75&t=67892 |
| Author: | JohnBrydon [ Sat Feb 13, 2021 12:14 am ] |
| Post subject: | Threading of circular hatch mount screws (Tandem Islander) |
The circular hatch mounts have 8 attachment bolts round their periphery. Do these bolts go straight into threaded plastic or do they have metal inserts? I have a bolt that appears to have stripped its thread and need to now whether I can get an another insert (if it exists) or whether I just need to drill out the hole and put in a bolt + Nylock nut as a replacement. |
| Author: | KayakingBob [ Sat Feb 13, 2021 2:50 pm ] |
| Post subject: | Re: Threading of circular hatch mount screws (Tandem Islande |
Or try a slightly larger diameter screw of similar type. |
| Author: | mmiller [ Wed Feb 17, 2021 10:11 am ] |
There is a plastic backing ring. You could add some epoxy in the hole and then set the screw? |
