| Stripped Drain Plugs http://www.hobie.com/au/en/forums/viewtopic.php?f=75&t=8007 |
| Author: | IslandInventor [ Thu Sep 27, 2007 8:25 pm ] |
| Post subject: | Stripped Drain Plugs |
When taking out the rear drain plug (next to the rudder) on my islander, I noticed a certain difficulty, and when I went to put it back in, I couldn't do so because of the holes being almost completely stripped! I ended up re-inserting the plugs with the help of a wrench, and have had to use a hand pump to drain the yak ever since... I’m thinking about installing a separate drain plug, but am wondering if it’s worth the trouble, or whether I should just stick with the pump… I have also noticed this problem with the seat drains, but I usually leave those open, since I'll end up soaked anyways. |
| Author: | IslandInventor [ Fri Sep 28, 2007 8:49 am ] |
| Post subject: | |
I checked it, and it's actually the plastic of the hull that is shreded! the hand pump works ok, so i'll probably stick wit hit... thanks for advice. |
| Author: | KayakingBob [ Fri Sep 28, 2007 8:54 am ] |
| Post subject: | |
When I first got my Islands I always used the drain plugs, but after breaking a rudder pin (it wasn't the main cause) and looking at how the hull had to be held to get all the water out, I started pumping and then using a sponge for the rest. Seems to be quicker, safer (AND LIGHTER)! Kayaking Bob |
| Author: | sunjammers [ Fri Sep 28, 2007 10:43 am ] |
| Post subject: | |
We never use the drain's I think they could do away with them, as long as you left a hatch open for it to air. we trow a shammy sponge in the front of all the kayaks, works great!
| Author: | kepra [ Sat Sep 29, 2007 8:25 am ] |
| Post subject: | |
when driving from 200' to over 5000' expanison in the ama. On the return trip the ama will suck in... if not vented..requiring continued use of the plugs. the reason I do not like to operate them is that continue use causes wear and possible misalingment. Once the threads are worn??What then...leakage...pumping |
