| Noisy rudder control http://www.hobie.com/au/en/forums/viewtopic.php?f=78&t=40656 |
| Author: | Capt.Shawn [ Tue Dec 20, 2011 1:35 pm ] |
| Post subject: | Noisy rudder control |
I love my 2012 PA ,the 1st few trips the boat was fine but on the last trip i started to hear a tight spring type noise coming from the rudder control.No matter how soft ,fast or slow i move it ,it makes the loud sound but it turns fine.I took the cover off the rudder cam in the aft of the PA to see if the string was maybe to tight but it was not.Please help........ |
| Author: | mmiller [ Tue Dec 20, 2011 1:42 pm ] |
| Post subject: | Re: Noisy rudder control |
Perhaps the spring is chirping as it rotates with the steering handle? You might shoot some silicone on the internal fittings just below where the handle is mounted. |
| Author: | Capt.Shawn [ Tue Dec 20, 2011 1:46 pm ] |
Worth a shot thanks I will try.Thanks for the fast reply.. |
| Author: | Jollymon [ Tue Dec 20, 2011 1:53 pm ] |
I had the exact same issue with my Revo. A little shot of lubricant and she's quiet as a church mouse. |
| Author: | Capt.Shawn [ Tue Dec 20, 2011 2:10 pm ] |
How do i remove the handle?or don't i have to |
| Author: | mmiller [ Tue Dec 20, 2011 4:14 pm ] |
Go in through a hatch and squirt from inside the boat. No need to dis-assemble. |
| Author: | Capt.Shawn [ Tue Dec 20, 2011 4:33 pm ] |
Thanks a bunch all. |
| Author: | Jollymon [ Tue Dec 20, 2011 6:21 pm ] |
mmiller wrote: Go in through a hatch and squirt from inside the boat. No need to dis-assemble. Yeah, what he said. |
| Author: | PI Lvr83 [ Wed Dec 21, 2011 12:19 pm ] |
My PA does the same thing, sounds like it is binding somewhere. Is it best to get to the area from under the lure storage? What exactly am I looking for? |
| Author: | Redsman [ Sun Feb 19, 2012 12:42 pm ] |
Mine is doing the same thing. I'd like to know how you fix it if you find the problem. |
| Author: | Capt.Shawn [ Mon Feb 20, 2012 12:26 pm ] |
I did what everyone said to do and it worked.I sprayed some silicon on the rudder control and have not had a problem since.GOOD LUCK. |
| Author: | brickthor [ Mon Apr 02, 2012 4:59 pm ] |
Mine did the same thing out of the package. It is just the the crimp on the end of the line rubbing over the rudder control arm just beneath the handle. When it is turned all the way to one side or the other the crimp barely slides over the arm and makes the string sing like a guitar. I left mine alone after I found what it was but when the line gets replaced I will move the crimp further back so it won't catch the control arm at the sharper angle. To check yours, just look at it through the tackle box hole in front of your seat with the rudder down while turning the rudder handle. Preferably on land...lol Hobie, take note and you can prevent this minor inconvenience by crimping the rudder line further back. |
| Author: | Capt.Shawn [ Tue Apr 03, 2012 8:48 am ] |
Good info thanks. |
