| Epoxy or not to epoxy? That is the question. http://www.hobie.com/au/en/forums/viewtopic.php?f=78&t=46303 |
| Author: | Flyfsh [ Sun Jan 20, 2013 6:09 am ] |
| Post subject: | Epoxy or not to epoxy? That is the question. |
Instaling a fishfinder on a 2013 PA12. It has the built in spot with the mount. One set of instructions I have say to glue the transducer to the bottom for a through hull application. The other directions I have say to leave a 1/2" gap betweem the transducer and the bottom. Any insight please? Jim |
| Author: | Lunker1 [ Sun Jan 20, 2013 6:19 am ] |
| Post subject: | Re: Epoxy or not to epoxy? That is the question. |
I have the same boat. My instructions did NOT say to epoxy anything. I have the 1/2" gap between the transducer and the mounting plate base on my Lowrance Elite-4 DSI and it works perfectly. I would not epoxy it in place. Besides not being able to remove it if you had to, you run the risk of bubbles in the epoxy that will disturb the sonar image or the transducer getting mounted crooked permanently. There is no advantage to the epoxy but there are advantages to not using it. |
| Author: | Flyfsh [ Sun Jan 20, 2013 6:52 am ] |
Thank you. I thought the same. Jim |
| Author: | wolfewiz [ Sun Jan 20, 2013 7:51 am ] |
my bad...read it fast and forgot and wasnt thinking of the 2013. |
| Author: | Flyfsh [ Sun Jan 20, 2013 8:45 am ] |
LOL, Wolf did you read my post? Duck Seal for what? Jim |
| Author: | Marble Man [ Sun Jan 20, 2013 2:36 pm ] |
Lunker1 wrote: I have the same boat. My instructions did NOT say to epoxy anything. I have the 1/2" gap between the transducer and the mounting plate base on my Lowrance Elite-4 DSI and it works perfectly. I would not epoxy it in place. Besides not being able to remove it if you had to, you run the risk of bubbles in the epoxy that will disturb the sonar image or the transducer getting mounted crooked permanently. There is no advantage to the epoxy but there are advantages to not using it. +1 also using the duck goop will delay an accurate temp reading. I'm running a 798 HB, Perfect Picture. |
| Author: | Lunker1 [ Sun Jan 20, 2013 6:17 pm ] |
Marble Man, Good observation, I did not think of that but you are right! |
| Author: | Flyfsh [ Fri Jan 25, 2013 6:09 am ] |
I installed it without any type of adhesive. I mounted it 1/2" off the bottom. I took it out wed and everything works great. Jim PS: Caught a few small walleye and 1 crappie. |
